This is a discussion on Just blew a few 100 $ within the Member Show-Off & Photography forums, part of the Community - Meet other Enthusiasts category; What pressure do you guys think the OEM BPV can handle safely? 16 seems a bit low since stage 1 ...
What pressure do you guys think the OEM BPV can handle safely? 16 seems a bit low since stage 1 + sf intake on 91 octane peaks at 16 and I havent seen any troubles yet.. And stage 2 is 17 psi. I was thinking somewhere around 18, 18.5 psi should be the safe limit, or what do you think?
Justin ~ 2011 WRX (WRB Sedan) ~ 275whp/299wtq
Build Thread Beloww:
http://www.clubwrx.net/forums/builds...-2011-wrx.html
Greg
www.modmeets.com
ProTuned Stage 3 '11 WRX Ltd HB (SWP) ~ 342 awhp 399 ft-lb tq on E85
Mods Blog Post
Friends don't let friends drive Mitsubishis.
-Chris Z.
12/27/11 - Ordered
01/16/12 - Received
2012 WRX Hatch World Rally Blue
L.E.D Lights Swap, KB STS, Cobb Shifter Knob, Kenwood DDX 719 7", H.I.D.'s
Greg
www.modmeets.com
Mods Blog Post
Greg
www.modmeets.com
Mods Blog Post
Forge BPV
Works...but I miss the sound of the Turbosmart
Greg
www.modmeets.com
Mods Blog Post
Nope, no mods needed for a BOV. If you're concerned about running it as a hybrid, you can just screw in the block off plate, which makes it full recirculating. I tried both, and both worked fine....hybrid setup was louder of course.
Greg
www.modmeets.com
Mods Blog Post
I ran an AVO 380 turbo at 18psi on the stock BPV with no problems. Then I switch to the GFB hybrid ran on 50/50 and that worked good for a couple years then when I got the 20G it started leaking, so now I run the Cobb XLE on full recirc and so far its the beast one I have owned yet.
