Results 1 to 15 of 16
This is a discussion on No more project, bought a new car...2009 STi within the Member Show-Off & Photography forums, part of the Community - Meet other Enthusiasts category; I'm sure some of you know that I was planning on an EJ20 Motor Build on the 2005 WRX There ...
    ClubWRX.net Vendor KronosPerformance's Avatar
    Nov 2005
    Bordentown, NJ
    There were a lot of personal reasons why I stopped doing it and bought a new car...part of it was that it became less fun and more money intensive. I'm not saying that I didn't know how much money I was going to spend initially but that was supposed to be somewhat fun. There are other reasons why but its not due to a failed project or anything, was a decision I made before I got too deep into it (I only went 1/4 deep lol).
    FYI, all the motor parts bought are being sold...
    FS: (For Sale) Selling EJ20 Motor Parts, Block, Built Head, CP Pistons & More - NASIOC
    Anyways, here is a picture of it...its a 2009 Subaru STi, 29,000 miles on it...100% stock, brand new tires. Was traded in because the previous owner joined the army and was traded in 3 weeks ago at this dealer, so its not one of those auctioned cars. I got a good deal for it and its exactly what I was looking for.
    ClubWRX.net's #1 Vendor! - www.kronosperformance.com - Call/Text 732-742-8837 |
    AIM Screenname - KronosParts | GoogleTalk - sales@kronosperformance.com | Military Discount
    [/SIZE]
    USE COUPON CODE FIRST5%OFF to receive a discount of your first order
    Kronos has Special Pricings on Process West & Agency Power!
    CONTACT US DIRECTLY FOR SPECIALS AND PROMOTIONS
    What's wrong with an auctioned car?
    Car looks good. Staying modest (StageII+) with this one?
    Nov 2005
    Bordentown, NJ
    I didn't mean to make it sound like there was something wrong with it...I only said it because thats how I knew about the info on the previous owner.
    I'm staying stock for a while to be honest. My main thing was to have a nice comfortable quick daily driver which it is. It helps me get around slow cars in NJ and aggressive SOBs in NJ as well. Plus I got larger car payments than I did before
    [/SIZE]
    Quote Originally Posted by KronosPerformance
    I'm just busting balls.
    At least have your buddy do a mild reflash on it so you're not rebuilding another motor. The stock tunes are horrid...
    Nov 2005
    Bordentown, NJ
    O Rly? Run very rich?
    [/SIZE]
    Negative pantsy rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    Congratulations Adam!!!
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    The Big 2011/2012 Mod Thread
    "Just Leave me alone. I know what I'm doing"-
    Kimi Räikkönen
    Mar 2010
    Akron Oh
    Quote Originally Posted by KronosPerformance View Post
    i said this once to someone, thought it was a good example...
    i have a lot of time looking at the stock tune. its very unsafe for any boost! when in boost a perfect target is about 10.8-11.2 AFR. the stock tune WILL allow full boost and WILL run about 14.5 AFR all the way to about 4500 RPM (max boost has already come). 14.5 AFR is target for normal driving or what they call stoich/stoichiometric ratio/per unit air. this happens because of a long CL/OL (closed loop/open loop) time delay. every tuner sets this to zero i believe so your not running super lean during the transition time going from normal driving to wide open throttle (hense CL/OL time delay in the ECU). now your car has a back up item so your motor doesnt blow up "kinda". its called your knock sensor. when you run that lean you will be knocking like a mofo! when knocking the ECU will pull timing but it will not pull boost or increase fuel. basically its all bad.
    here is a pic of an OEM tune knocking a few times and losing a ton of power due to pulled timing. the bad thing about our motors is our pistons are not that strong. enough knock events even with pulled timing can form micro cracks or even break the ringlands of the pistons. if they slightly mirco crack it wont take much time after increasing power for a piston to completely break.
    also in 08 on the wrx and sti subaru started doing this "balance hose" thing on the fuel system. its a hose that will allow fuel coming from the tank to go into the return line. every car i have ever worked on the fuel system has always been a straight line. fuel from tank, through injectors, back to tank. a lot of tuners have hated this balance hose and most remove it. it also helps because a lot of these car have this stumble on decel.
    PS since 08+'s starting breaking as much or a little more then older models im about 98% sure you only get a 1 time free motor replacement.
    Nov 2005
    Bordentown, NJ
    Quote Originally Posted by rage-wrx View Post
    Thanks
    [/SIZE]
    Sammich Makin' Princess Leia wrxtreme06's Avatar
    May 2007
    orlando flawduh
    congrats on the new car!
    desiree
    06 impreza wrx tr
    : cobb stage II - protuned by STi_Mikey!
    hawk-eye alliance #11:11 //
    wingl3ss @ll!ance #17 // lvl 80 N.E.R.D.
    facebook
    Nov 2005
    Bordentown, NJ
    Thanks
    [/SIZE]
    Toboggan T0rque's Avatar
    Dec 2004
    Your Mommas
    pregnancy still happens at any depth
    Lead Wrench @ WTF Tuning, LLC
    Quote Originally Posted by T0rque
    That's what IDP is for...
    While synolimit posted a graph already, that was a 2011 and had other overlaying graphs. 2009 Stock STI:
    Registered User xFalleNx's Avatar
    Nov 2010
    Moorestown, NJ
    I know I already told you, but congrats again man! I can't wait to see it!
    --Anthony 2011 DGM WRX stg2+sf intake + custom front end deer mod!
    Official Subie owner as of 01/10/11
    Stink Eye Mob #87
    Bye bye Bimmer
    Hellooo '11 REX
    Nov 2005
    Bordentown, NJ
    Quote Originally Posted by xFalleNx View Post
    Thanks man, I appreciate it.
    [/SIZE]
    Jul 2011
    are you selling the pistons?
