can i run ap stage2 with catless invidia downpipe and mid pipe with stock axleback
Results 1 to 8 of 8
This is a discussion on can i run ap stage2 with catless invidia downpipe and mid pipe with stock axleback within the Member Show-Off & Photography forums, part of the Community - Meet other Enthusiasts category; i have a 2006 sti with invidia catless down pipe and cat back g200 but its too loud and im ...
    Nov 2011
    i have a 2006 sti with invidia catless down pipe and cat back g200 but its too loud and im wondering if i can put the stock axleback from 2006 sti on with stage 2???? not worried about fitment im worried about running stage two with stock axleback... has anyone done anything similar??:confused:
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    I ran a protuned stage 2 with stock sti cat back.. Kevin is running a turbo swap with nearly 400 hp and a stock sti cat back
    Lead Wrench @ WTF Tuning, LLC
    Apr 2007
    8000' up in Colorado
    You need to get a reducer to go from the 3" DP to your 2.5" stock catback, but otherwise it's fine. Some people even run without the reducer, but then you've got a good chance of exhaust leaks.
    Scott
  5. #4
    The stock catback even looks great. It's the least likely to attract attention or get damaged by scraping etc. I think it's actually a good choice.
  6. #5
    The Fruit mangostick's Avatar
    Oct 2009
    VB VA .. the ghetto on the sea
    running the invidia catted dp with a spt cbe exhaust, I just double gasketed the flange meeting from dp to cbe and no leaks to speak of.
    Running the adapter as ^ Mr. Jones suggests IS the best way though if you're in a pinch you can just run two gaskets. The invidia dp has a really nice healthy end flange so you can tighten the bolts down pretty snug without worry of distorting the flanges and getting leaks.
    OBP 2010 5dr *traded*
    SWP 2013 FRS
    SUCH IS MANGO!
  7. #6
    Nov 2011
    Thank you guys so much I have gotten the axle back rewelded to fit the invidia mid pipe so I can take the axleback on and off for the track but I will be running stock axleback for dailydriver and invidia for track purposes. Also wondering if I buy the stp gt3076r bolt on turbo kit for stock location, will I be able to install it by my self or will I have to take it to a
    shop.
  8. #7
    Registered User GarrettKoonsman's Avatar
    Apr 2009
    CO
    Quote Originally Posted by 2006subaruSTI View Post
    shop.
    This completely depends on your mechanical abilities. You do know that swap requires a LOT of other modifications to work right? Injectors, fuel pump, intercooler and while your at it potentially some port and polish work all with a new tune.
    And your motor is going to struggle to maintain 500hp. Your looking at many thousands of dollars to get that done properly
    2003 Midnight Black Pearl WRX Sedan
    200.7 AWHP Protuned Stage 2 at 5400ft above sea level
    Bugeye Mafia Member #225
    Mods
    Pics
  9. #8
    ClubWRX.net Vendor adam@kronosperformance's Avatar
    Nov 2005
    Princeton, NJ
    shop.
    Do you mean ATP?
    What kind of power are you aiming for? Thats a pretty decent size turbocharger and there are other supporting modifications I would recommend if you're seriously looking to do this. Also are you building the motor?
