This is a discussion on Here's my car 2011 WRX! within the Member Show-Off & Photography forums, part of the Community - Meet other Enthusiasts category; Originally Posted by Gretsch308 Have either one of you been to Maine before??? You would understand if you had. Also ...
I thought they where notorious for shorting their customers.
There are lots of places in the US that don't get 93. CA has a max of 91, here in WA 92 is the max. The octane rating has little to do with the shape torque curve, and more to do with how high it goes.
IIRC the difference between 91 and 93 is about 5HP at stage 2 levels.
If you're doing an internet tune, send the logs to the tuner, and have them fix it. If you did the tune locally, make them fix it.
Why must people compare graphs and hp numbers with so many variables to consider?
Is it because someone with less mods made more power than you?
Does that make them wrong?
Does that make the tuner bad?
You have no comparison unless you have been tuned by the same tuner on the same dyno.
Bren Tuned BNR HTA68 on a 08 LGT SPEC B
Bren Tuned 20G on a 05 LGT 5EAT
Bren Tuned 2011 WRX
Bren Tuned 02 WRX Hybrid HTA68
If someone can find me a negative review I would like to see it.
Here is a link to his site
The numbers have nothing to do with the conversation, I personally was concerned with the peaks and valleys. I'm not bashing the tuner but the tune isn't right. The baseline tune is bad because the WRX runs leaner than it should from the factory, that's why a tune is such a good first mod. But a good tune will smooth that out to look like Kevin's (sinster) tune. As long as the conditions that you drive in are close to the conditions that you were tuned in (elevation, gas quality, temp, etc...), there is no reason the hp/tq curve should look like that. It should be revised.
PS. did you join the forum to post that comment? And honestly, looking at those other dyno plots, I wouldn't be happy with any of them. But that's just me, people seem to be pleased with his work.
Stink eye mob #727
2011 WRX DGM Hatch, Protuned Stage 1
No I did not join just to post that. The 05 LGT was the first to use that style turbo/intake manifold. Thanks to the 08+'s the aftermarket boomed for the weary old EJ255!
Quote from Bren himself about this dyno graph:
"There is zero smoothing with a dynapack. You see everything! Some people lower the ramp rate and have the car zing through the gear. We leave it at factory dynapack trained settings. I think I am one of the few dynapack guys who does it correctly. Also depending on the floor surface or suspension the car will vibrate a bit on the dynapack.
On an old dyno dynamics or mustang (like that was posted) you cant see even see a 20wtq boost oscillation or knock event in the curve as the x and y axis's are scaled 0 to 500hp/tq. Even a stock tune would look great on that."
The printout was scaled to 500 so you can see the curve under the headings. The tuner (harvey) changed the curve progressively from 250 to 300, to 350, to 400 as my car went up in power. In addition, knock is detected by the ECU. Incredibly enough... the tuner had the knock sensor up the whole time while tuning (along with the misfire boxes). Along with the boost sensor, and AFR. So boost oscillation (which would have caused a lean condition) would be noted.
I guess... my question would be... if you see that much bouncing around due to "the floor surface or suspension" vibrating... then how can HE see a 20wtq boost oscillation or a knock event on his dyno graphs? The damned thing is bouncing around so much that it looks like every 300rpms there's a problem. Also.. if you look at the major peaks and valleys... they're in the same places as the stock map... which makes one think he was super lazy with the tuning.
If you look at his website, a lot of his dynos look 100x better than the one you posted. So I don't buy the explanation.
Here's a good looking one from the same tuner, and the same dyno:
And another:
Just so you can see one of my tunes scaled to only 360whp... Here's my pump gas tune, which I asked to be very reserved (at only 330whp).
The bottom line is that the car drives amazing and I feel I got a great deal with what I was charge. I also value all these opinions but guess what, it's my car and it does not bother me that my tune is "bumpy". I plan on doing a bigger tmic and down pipe in the spring and will be going right back to Bren.
Stink eye mob #727
