**Nominees for February 2011 ClubWRX Car of the Month**
Closed Thread
Results 1 to 15 of 23
This is a discussion on **Nominees for February 2011 ClubWRX Car of the Month** within the Member Show-Off & Photography forums, part of the Community - Meet other Enthusiasts category; Let's see how this goes.... The theme for the first ClubWRX Car of the Month contest is BEST BUGEYE!! Clean ...
    Administrator Justin@ClubWRX's Avatar
    Oct 2010
    Irvine, CA
    Arrow **Nominees for February 2011 ClubWRX Car of the Month**
    Clean and detail those bugeyes and post some updated pictures with a modlist in this member show-off and photography thread to be nominated! Winners will be featured on the ClubWRX.net homepage, a soon-to-come ClubWRX Hall-of-Fame thread of COTM winners, and will receive a free set of ClubWRX.net car decals.
    Simple set of guidelines:
    1. Nominate a car you think is worthy of Car of the Month status in this thread
    2. You may nominate as many cars as you want, including your own
    3. Nominees must be a member on ClubWRX.net
    4. Members' cars must be current. (currently owned, not parted out, etc.)
    5. All cars entered must have pictures displayed somewhere on ClubWRX.net (ie. a thread in the member-show-off & photography section or in an album)
    6. Try to include a link to their member showoff thread with the nomination
    7. Nominations will end Friday night, Feb 11
    8. 3-5 of the top nominees will make it to a poll thread, which will last the duration of the month
    GO!
    Justin
    ClubWRX.net Admin
    Quick reply to this message Reply
    Feb 2011
    Port Perry, Ontario
    2002 Bug Eye 2.5 RS
    I would like to nominate my 2002 RS Bug Eye...
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    do you have a mod list, or any background info on the car, etc?
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  5. #4
    Feb 2011
    Port Perry, Ontario
    2.5 RS..
    The car is standard except for the rear spoiler, and tinted windows. The car is a 1 owner car from 2002. Currently has 148,000km and is original.
  6. #5
            MainFrame's Avatar
    Austin, TX
    I nominate.. my car! lol
    I don't really think my car is worthy for COTM, but here it is anyways.
    2002 WRX - ~105,000 miles
    Engine Mods:
    port and polished ej205 intake manifold
    port and polished throttle body with coolant bypass
    8mm GrimmSpeed phenolic spacers
    port and polished TGV deletes
    ej205 heads opened up for +1mm BC valves w/radiused valve job
    900cc modded STi pink injectors
    Walbro 255LPH fuel pump
    ej257 shortblock bored .5mm over
    ej257 crank and rods
    ARP rod bolts
    CP 100mm pistons
    11mm STi oil pump w/two shims
    ACL race bearings
    ARP head studs
    Cometic EJ25 100mm .027 inch MLS head gaskets
    Borla replica header/uppipe combo wrapped
    TurboXS catless stealthback w/Summit Racing 3" manual cutout
    Perrin SRI
    AEM dry flow air filter
    TurboXS FMIC
    Power Enterprise aluminum radiator
    Forge Recirculating Race blowoff valve
    Peterson catch can
    Maniac Electric 160amp high output alternator w/diode mod
    IHI VF22 w/polished exhaust intake
    homemade turbo blanket
    GrimmSpeed 3-Port EBCS
    fully balanced rotating assembly
    Optima Yellow Top battery
    home made grounding kit
    "big 3" wiring additions (4 gauge)
    open source EM
    tuned by AWDTuning
    Driveline mods:
    ACT HDSS clutch
    ACT street light flywheel
    JDM cryo treated & micro polished STi 5MT gearset w/dual cone first gear syncro
    JDM heavy duty center diff.
    Kartboy short shifter w/all the bushings
    Perrin rear diff. lock down system
    STi axles and hubs
    Brembo GT series big brake kit
    Goodridge SS braided brake lines
    18"x8.5" Rota wheels
    235/40R/18 tires
    Suspension:
    Tein Flex coilovers (currently being shipped to Tein to be overhauled)
    KYB AGX gas adjustable struts w/Group N hardened tophats (currently on the car)
    Eibach prokit springs (currently on the car)
    Whiteline steering rack bushings
    Exterior:
    mock carbon fiber side marker inserts
    mock carbon fiber "I" badge
    Hella fog lights
    wingless debadged trunk
    tinted windows
    Interior:
    reverse indiglo gauge cluster
    blue LED HVAC conversion
    AutoMeter A-Pillar 3 gauge pod
    Prosport Blue/White Exhaust Gas Temperature Gauge
    Prosport Blue/White Electrical Oil Pressure Gauge
    Prosport Blue/White Mechanical Boost Gauge
    Alpine iDA-x305 headunit
    Alpine PDX-4.100 amplifier
    Metra 6.5" speaker spacers
    Kenwood tweeters (front doors)
    Infinity Reference 6.5" coax speakers (front doors)
    Sony Xplod 5.25" coax speakers (rear doors)
    Cerwin Vega 5"x7" coax speakers (rear deck)
    Boss Audio BASS600 8-Inch Low-Profile Amplified Subwoofer (under driver's seat)
    14 gauge speaker wire all around
    120gb Toshiba 2.5" .mp3 hard drive
    Momo air leather shift knob
    NRG Gen 2 steering wheel quick release kit
    Momo JET35BK0B Jet Black 350mm Leather Steering Wheel
    Subaru mock carbon fiber trim inserts
    Tactrix 1.3U cable routed behind dash
    Grip-It phone mount
    driver's side airbag resistor mod
    hard wired power inverter between driver's seat and center console
    The car is currently in the shop getting new piston rings, ej257 cams, rod bearings, GrimmSpeed turbo heat shield, and Manley H-beam rods installed. I am also shopping for a Blouch 20g-XT (or Dom1.0XT) to go on it once I'm through the next break in period.
    Next mods after the turbo and e85 tune are going to be Whiteline swaybars w/Kartboy endlinks (and I'm getting a blue lens for the odometer.. and I have a homemade aluminum skidplate in the works, and I'm thinking about getting a cheap generic front strut brace bar).
    I don't have any recent pictures, but here's one from a while back..
  7. #6
    Oct 2010
    Irvine, CA
    Nice cars guys. Please create a seperate showoff thread to display your car. It'll be easier to vote on by linking to your individual threads than by linking to this one thread with everybody's cars.
    Justin
    ClubWRX.net Admin
  8. #7
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by Justin@ClubWRX View Post
    done
    Bugeye COTM nomination
  9. #8
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    Armins car has this on lock looks wise.. Performance wise would be jen and Bobbys RWD beast Sorry guys..
    Lead Wrench @ WTF Tuning, LLC
  10. #9
            MainFrame's Avatar
    Austin, TX
    true, but they haven't entered yet
  11. #10
    Registered User drakejesus231's Avatar
    Feb 2010
    Santa Cruz, California
    What the heck here ya go (MINE) (too bad this isn't like 2 weeks from now I just ordered 18x10 Grids and S202 Wing) BOO!
    Bugeye Mafia #326
  12. #11
    Admin - Scooby Hooligan
    Weasel 555's Avatar
    UK,NY,AK,FL
    does it have to be currently owned or one you have owned ?
    ScoobyDMC #000,HawkEyeAlliance#000,Blobeye Syndicate #000, SQC-NY #009, "Dragon Slayer"
    "All We'll Drive"
    Subaru Worldwide/Rallying: facebook.com/groups/subarumad/
  13. #12
    Dec 2003
    Dallas, TX / Sterling, VA
    Hmmm...
  14. #13
    Q RayfieldsWRX's Avatar
    Oct 2002
    The Old Folks Home
    Seems to me that a winning entry should be well-rounded...? Appealing looks and performance? and extra points given for entries by members over 40...
    --Ray
    "Bro ima get Bimota BB3 because expert. My parents have 911 turbo but awd won't let me launch, ima get 962 twin turbo Group C bro." -- SD_GR
    2013 Subaru BRZ Limited
    2002 Subaru WRX Bugeyebrid Wagon -- SOLD
    2002 Subaru WRX Sedan -- SOLD
  15. #14
    Oct 2010
    Irvine, CA
    Good point Weasel. Fair enough that the car must be current to date? I'll add that to the OP.
    Personally I like all show and no go and I'm sure there's members that feel the exact opposite. We'll see how it turns out in the poll next week.
    Justin
    ClubWRX.net Admin
  16. #15
    Princess Moderator
    03WRX_YELLOW's Avatar
    May 2004
    Gresham, Oregon
    Quote Originally Posted by T0rque View Post
    I can put the Yellow Beast up.... We've been working on this what seems to be an ON-Going project since 2004.(because it is!) Originally bought for me for my Bday and was at one point, my daily driver for 2 years. Then one day Bobby and an awesome idea of making it into a full drag car and RWD! And he hasn't stop with this car yet. He is now relocating the turbo once again and is in the middle of doing all the fab work himself. Hes trying to get things done for this race season. Last year we ran into some issues with tranny flex plate and went sent the motor off to darton to get sleeved. We will see what this year will get us. Keep your fingers crossed. Hoping for low nines !!
    MOD LIST
    Model: 2003 Subaru WRX
    Power: 400hp 460tq
    Weight: 2260lbs
    Track Times:
    Battle of the Imports: 10.62 @ 124mph
    Engine:
    EJ257 Block 2.5L
    CP Forged Pistons 9.0:1 compression
    ARP head studs
    GTSpec header & uppipe combo
    - modified for rotated setup
    HKS 3" bellmouth downpipe
    Custom 3" exhaust with twin turndowns
    Custom 3" intake
    MAF delete
    9" AEM Dry-flow air filter
    AEM engine management system
    Forced Performance Red turbo
    Custom rotated turbo setup by PREracing
    Turbosmart Hypergate45 external wastegate
    TurboXS intercooler
    Custom intercooler piping
    Reverse mounted intake manifold
    Hondata heatshield intake manifold gaskets
    Fuel System:
    Modified stock injectors
    Perrin fuel rails
    Aeromotive A1000 inline fuel pump
    Aeromotive inline fuel filter
    Aeromotive rising rate fuel pressure regulator
    Steel Braided -8 fuel line
    Aeroquip Aluminum AN fittings
    JAZ 5g fuel cell
    Transmission and drivetrain:
    Turbo 400 3-speed auto transmission
    Hughes 6,000 stall converter
    Transbrake
    Straight cut planetaries and kevlar bands
    Custom adapter plate
    Reverse mount circle track starter
    Narrowed Ford 9" rear end
    Strange full spool
    Custom driveline
    Strange Axles
    Strange Carrier
    Suspension:
    Endura-tech coilover suspension (front only)
    Custom 4 link rear end suspension by RPM Chassis
    Custom panhard bar by RPM Chassis
    Rear coilovers
    Wheels and Tires:
    15x14 Weld ProStars aluminum wheels
    Goodyear 32x16/15 slicks
    Frontrunner Skinnies on order
    Interior Mods:
    Stripped interior
    Autometer boost gauge
    Innovate wideband A/F meter
    Autometer monster tach
    Autometer speedometer
    Autometer water temperature gauge
    Autometer oil pressure gauge
    Sparco steering wheel
    JAZ aluminum drag seat with cover
    Chromemoly full roll cage by RPM Chassis
    Full tubbed back half, all tin work by RPM Chassis
    Custom wiring by Bobby at PRE (all body harness removed and re-wired)
    Exterior:
    Carbon fiber hood with vinyl accents
    2006 STI rear bumper
    2004 STI rear taillights
    Polycarbinate windows
    Some Pics of the Yellow Beast
    Recent Paint Job - Ford Blaze Yellow
    Battle of the Imports 2010 - Best Overall Subaru
    Last time tracked in 09
    A few interior pics
    Jennifer - "Consigliere" for the Bugeye Mafia
    ScoobyDMCtt - Blobeye Syndicate #007
    04 STi ECU - with Protune - FSTi Garrett GT40 -- 422whp-more to come... 12.86 @ 105
    BoBBy TuNED@ preracing.com --- DIFFERENT STROKES
Closed Thread
