Behind the Scenes: WRX for Modified Magazine
Results 1 to 11 of 11
This is a discussion on Behind the Scenes: WRX for Modified Magazine within the Member Show-Off & Photography forums, part of the Community - Meet other Enthusiasts category; Hi everyone, Im semi-new here. I havent posted in a while. I do freelance automotive photography for Import Tuner, SuperStreet, ...
    Registered User Orlandoech.com's Avatar
    Oct 2009
    Hi everyone, Im semi-new here. I havent posted in a while. I do freelance automotive photography for Import Tuner, SuperStreet, Modified and Performance Auto & Sound. I had a shoot this weekend for Modified Magazine, it was a Track WRX. Feature coming soon, Ill post pics once Im able to. Until them check me out at www.Orlandoech.com
    My Blog - My Facebook - My Flickr
    For more pics check out; wrx photo shoot - a set on Flickr
    and Index of /Orlando
    Here is the mods list;
    2006 WRX
    Engine:
    Cosworth 9.2:1 compression long block
    Cosworth big port cylinder heads
    Cosworth 274/278 camshafts
    APS TSR70 turbo kit .82
    APS Twin scroll exhaust manifold
    APS 80mm intake
    APS 3.5 inch turbo back exhaust
    APS Fuel rail system
    APS TGV deletes
    APS DR525 front mount inter cooler
    Tial 44mm waste gate
    Aeromotive Fuel pressure regulator
    Deatschwerks 1100cc fuel injectors
    SARD 5L surge tank w/ -6AN lines
    Denso 280lph fuel pump in tank
    Walbro 255lph fuel pump x2 in surge tank
    Gizzmo phenolic spacers for intake manifold
    COBB tuning crank pulley
    Moroso high volume aluminum oil pan/ pick up
    Cusco solid engine mounts
    Crawford performance air/ oil seperator
    Transmission/ Drive train:
    PPG 1-4 straight cut gear set
    PPG billet selector forks
    Cusco 1 way front LSD
    Cusco 1.5 way rear LSD
    Cusco solid transmission mount
    ARP extended wheel studs
    Carbonetic 1300 twin plate clutch
    Kartboy short shifter
    Suspension/ Brakes/ Chassis:
    Tein Monoflex coilovers 10k/7k
    Tein front/ rear camber places
    Hotchkis lateral links
    Whiteline 25mm front sway bar
    Whiteline endlinks
    Whiteline bushings (rear diff, outrigger, steering rack, etc)
    Cusco rear subframe brace
    GT spec 14 point front subframe brace
    Strut bars
    Stoptech 332mm front big brake kit
    Stoptech 2 piece slotted front rotors
    Stoptech SS brake lines
    OEM STi Brembo rear calipers
    DBA 4000 slotted rear rotors
    Porterfield R4 brake pads
    Interior/ Electronics:
    Defi 60mm gauges (boost, oil pressure, oil temp, water temp, EGT)
    Defi V2 link system
    Innovate wideband o2
    Apexi AVCR electronic boost controller
    Custom one off shift knob/ shifter extension
    Sparco Pro2000 seats
    Sparco 5pt harness
    Prodrive steering wheel
    Splash extended up w/ NRG slim quick release
    Beatrush bulk head divider
    Autopower 6 point roll cage
    Exterior/ Aero:
    Cleverley Tuned front air splitter/ limited lip
    APR canards
    APR GTC300 spoiler
    Voltex rear diffuser
    KS-Tech hood scoop delete
    STI roof vaine spoiler
    Nukabe tow hooks
    Wheels/ Tires:
    Street: Enkei RPF1 18x9.5 +38
    Falken Azenis RT615 245-40-18
    Race: Work 11r 18x9.5 +38
    Yokohama Advan 250-650r-18
    Power numbers:
    465whp 400tq 25psi 97octane fuel
    Tuned with the Cobb Accessport
    Nov 2009
    Where was that shoot. Those mountains look like they have lots of snow on them but you guys were all in short sleeves. Must have been in the desert somewhere.
    Must be a nice job.
    Peachypumpkincheeks
    Speedette's Avatar
    Aug 2005
    Sterling, Virginia
    Sweet gig, man! Very scenic photo spots! Thanks for sharing!
    Heather | 2002 WRX | Stage 2
    ScoobyDMCtt | Official Bodyguard #2 for the Bugeye Mafia
    TastesLikeAwesome | @Subiestar
  5. #4
    Oct 2009
    Quote Originally Posted by oguitar View Post
    Must be a nice job.
    It was in Ogden, UT just about 40 miles from Downtown Salt Lake City, UT. It was about 65 degrees out.
  6. #5
    Feb 2010
    SL,UT
    Quote Originally Posted by Orlandoech.com View Post
    I was gonna say I know that's utah just by looking at the mountians... nice pics though
    Hawk-Eye Alliance #801
  7. #6
    VietGuhTrippie's Avatar
    Apr 2009
    Denver, Colorado, United States
    Some really amazing compositions you have there on your website...
    You've got an awesome job too!
    Hawk-Eye Alliance #0136
    OBP '07 WRX TR tuned by Racing Trenz
    239whp 330.7wtq Corn fed
  8. #7
    Registered User GrtScott's Avatar
    Apr 2010
    Los Angeles
    Whats up with that boom on the roof of the car?
  9. #8
    Aug 2009
    Canada/Ethiopia/Madagascar
    Quote Originally Posted by GrtScott View Post
    It's a camera mount.
    ...Rob.
  10. #9
    Apr 2010
    Los Angeles
    ^ Haha... I know that. I guess the question would be... why would you use such a mount?
    I'd get it if in every picture it was supporting a camera all on its own but there is a guy holding the camera in every shot.
  11. #10
    Registered User Hold_Fast's Avatar
    Mar 2008
    Philly Burbs
    B-e-a-tiful scenery.
    ~Stan
    '04 WRB WRX Wagon (Build) - Hard Parked, AutoX Toy
    '08 WRX ~ Daily Beaten ~ '86 BMW 325es ~ "The Chump"
    "I was raised knowing there is a replacement for displacement, it's called engineering."
  12. #11
    Feb 2010
    SL,UT
    Quote Originally Posted by Hold_Fast View Post
    You think that looks good, check out southern utah ie monument valley, arches NP, zion NP, canyonlands NP, lake powell, and bryce canyon NP... southern utah makes the north look like kansas...
