CEL P0031 or P0032 Fix - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
This is a discussion on CEL P0031 or P0032 Fix within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; December 2011 bump as the WRX has generated the P0031 CEL. :/ Did some searching and this appears to be ...
    Apr 2004
    Southeastern PA
    Did some searching and this appears to be the most relevant thread here. So ... a sensor replacement is in order?
    Mods & Pics
    Moderator Donkey's Avatar
    Da boonies,Va
    Generally yes. Once the heater circuit is fried the sensor has issues cleaning itself. The reading will start to drift.
    2002 FORESTER S
    1998 FORESTER S
    Apr 2004
    Southeastern PA
    OK, thanks.
    Mods & Pics
  6. #19
    Jun 2011
    Suffolk County, NY
    I don't know about on the stock manifold but I removed the O2 on the up-pipe with a 22mm wrench
  7. #20
    Jun 2011
    Suffolk County, NY
    I'm getting both P0031 and P0032 simultaneously. Guessing it's pretty straight forward that I finally need a new sensor in the up-pipe huh? I just recently put in my 3rd or 4th tubular header as the flex pipe keeps going on them, I live on Long Island in NY and the roads are trash, in the winter we dump salt all over the roads and the flex pipe rots terribly. Luckily this header sat correctly on my head studs so not as much torquing as before.
LinkBacks (?)
