Page 9 of 11 FirstFirst 1234567891011 LastLast
Results 121 to 135 of 152
This is a discussion on Changing brake pads on WRX within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; Originally Posted by yo vanilla I've been looking for a good how-to on replacing the 4-pot pads and rotors, and ...
  1. #121
    Supporting Member mjboudreaux77's Avatar
    Sep 2007
    Northern Vermont
    Quote Originally Posted by yo vanilla View Post
    I've been looking for a good how-to on replacing the 4-pot pads and rotors, and the 2 pot rear pads but haven't found it. Anyone got a link?
    I am looking as well.. I have changed many American disc brakes, but these were very different. In the post, I read a user actually removed a bolt that let the brake fluid out. I am nervous now!
    I have an 07 WRX. I am just doing a simple pad/rotor replacement. Anyone know what size bolt is holding the rotor on?
    If I don't die by Thursday, I'll be roarin Friday night - Jimmy Buffett
  2. #122
    Oct 2005
    Late Devonian
    Quote Originally Posted by mjboudreaux77 View Post
    My 2003 rotors are just held on by the wheel lug nuts (assuming the parking brake is off).
  3. #123
    Jun 2009
    Does anyone know if this tutorial works on a 2002 Subaru Impreza Wagon? Thanks!
  4. #124
    Oct 2005
    Late Devonian
    Quote Originally Posted by druss15 View Post
    Should be very similar if not exactly the same. Check the bolt torque specs, that is the only potentially important difference.
  5. #125
    Jun 2009
    Will do, Thanks mycologist!
  6. #126
    Oct 2005
    Late Devonian
    Oh, it does have rear disks right? Drums are a different PITA.
  7. #127
    kjb
    kjb is offline
    May 2009
    Sounds like a lot of people really like the Hawk HPS pads. Are they worth the money? Has anyone had any trouble with them wearing out the rotors? My boyfriend had an issue on his car when he upgraded to ceramic pads that they were harder than the rotors. Maybe not an issue on the WRX? I'm planning to change the pads on my '02 and looking for recommendations on a good balance between price and longevity.
  8. #128
    Registered User Jonnyfilmboy's Avatar
    Sep 2005
    Van down by river
    Quote Originally Posted by kjb View Post
    I have slotted rotors and the Hawk HPS pads haven't lasted long for me (about 8 months) with no track days, just daily driving. So I think I'm going to use a different pad.
  9. #129
    Aug 2009
    Upstate NY
    i need to bleed my brakes and swap pads/rotors.
    should i bleed them before or after the pad/rotor swap? or does it even matter?
  10. #130
    Oct 2005
    Late Devonian
    Quote Originally Posted by Mekks View Post
    Since you are planning both, do fluid after. You need to compress the calipers and this is much easier (and arguably better) if you crack the bleeder. Attach your hose to the nipple (heh) to dump the fluid out of the caliper while you squeeze it shut, then close the bleeder before any air gets in. Then flush the fluid when you are all done with all 4 and it should be an easy job all around as long as you never let the fluid get too low in the reservoir.
  11. #131
    Aug 2009
    These instructions are incredibly helpful. I'm going to change my own brake pads for the first time ever next week. I have some questions about putting the car on jack stands.
    Can I put it up on one jack stand at a time? That seems to me like it would twist the car. If I do it two at a time, should it be front then back or passenger then driver. Or do I need to get it up on all 4 jack stands?
    Right now, I only have the jack that came with the car. If I use that jack and do more than one jack stand at a time, that will mean jacking it up, getting the jackstand underneath, then moving the jack and jacking up the next wheel. Again, I'm concerned about twisting the car and about whether that would rock the first jack stand.
    So how should I go about this? Any advice is welcome. Sorry for being so compulsive, but it's my first time doing this and brakes are serious.
  12. #132
    Sep 2007
    Northern Vermont
    Quote Originally Posted by RhinoRex View Post
    A good floor jack isn't very expensive - I just bought a 4 ton (overkill for the WRX, but not for my wife's van) from Sears for $99. Mine can pick the car up in the center behind the motor. This picks the car up evenly and then I can put the jackstands on the sides without the car tipping.
  13. #133
    Registered User lytlec's Avatar
    Jan 2009
    Central PA
    Either I'm missing it or it's not here but how do I change the front pads on an 06 wrx....No one seems to give a good explanation.
    <-------- Taylor Swift.
    99.5 Jetta...I hear they make 90 to the wheels....
    Hawk-Eye Alliance #137
    First Mods...what to do.
    Subaru Guide
  14. #134
    Jul 2004
    Seattle, WA
    Quote Originally Posted by lytlec View Post
    Here's post number 90 in this thread.
    Quote Originally Posted by williaty View Post
    If I recall correctly, the STi brake pads are removed/inserted through the side of the caliper, so the install is nothing like this tutorial. There's a video of the process on HSPN
    The WRX 06-07 process is the same as on the STI's.
  15. #135
    Jan 2009
    Central PA
    Quote Originally Posted by jeremy96gase View Post
    Duh! I should have realized that..ha! Thanks!!
    Subaru Guide
