ECU reset - Page 5
Page 5 of 5 FirstFirst 12345
Results 61 to 72 of 72
This is a discussion on ECU reset within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; I think what they meant was that with most newer cars (like 2000 and newer) you can't reset the ecu ...
  1. #61
    Jan 2010
    Loganville, GA
    I think what they meant was that with most newer cars (like 2000 and newer) you can't reset the ecu by just disconnecting the battery but have to hook up a reader or take it to the dealer to have them reset it. I don't know if they're talking about error codes and turning off the check engine light, etc. or just resetting it enough to allow it to "re-learn".
    I kind of agree because of past experience. I had a 1998 Dodge Neon and had something happen where the check engine light came on. To reset it, all you had to do was disconnect the battery for a little bit. My dad went and bought a 200 Neon and had the check engine light come on because he didn't tighten the gas cap good enough and tried to reset it by just disconnecting the battery and it didn't work. He had to take it to the dealer and pay to have it reset. The dealer said that with the newer cars, you have to take it to the dealer to get the ecu reset and can no longer do it by just disconnecting the battery.
    Is this the same situation with the WRX's (I have a 2004)? Never had the check engine light come on so I don't know. I have had a few times where I had the battery disconnected for a time (recently while changing the spark plugs) and noticed that it drove a lot better afterwords, but thought that was just because of the new plugs.
  3. #62
    Quote Originally Posted by mycologist
    I have read far more times that if you not only disconnect the bat. but drain the reserve power by pushing the brakes it will reset as opposed to this one post you link.
    This will work, and will erase all the "learned" values in the fuel trims, timing, etc. as well as clear any CEL.
    Resident Tuner @ WTF Tuning
  4. #63
    Moderator Donkey's Avatar
    Da boonies,Va
    People also need to understand the check engine light isn't going to magically go away unless the issue is resolved as well.
    2002 FORESTER S
    1998 FORESTER S
  6. #64
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    I am sorry but I have no idea what "non-volatile" means technically in this context. I have read far more times that if you not only disconnect the bat. but drain the reserve power by pushing the brakes it will reset as opposed to this one post you link. However, this is some seriously old school thread and I have personally only used an AP or a cable and romraider myself. I didn't reread the thread but I am guessing they are talking about riding your brakes to get your IAM up after a reflash. Don't do that. You can set where your map resets to in the editor.
    This is assuming you have an editor though. If not, the brake torque method does work...for a short duration. I proved it to myself at the strip. I wouldn't do this on a hot day though.
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
  7. #65
    Da boonies,Va
    You can also just run do a couple of quick WOT runs and the IAM should come up(if nothings wrong). You really don't have to do the "Vishnu trick".
    2002 FORESTER S
    1998 FORESTER S
  8. #66
    Jan 2010
    Ohio
    if you have a utec with tunes on it and you reset the ecu. it will load the tunes again and adjust for the remainder correct
    2002 WRX--Stage 4
    Tuned by TurboXS
  9. #67
    Registered User crue313's Avatar
    May 2008
    Charlotte, NC
    Will resetting the ecu clear CELs?
  10. #68
    Jun 2012
    Quote Originally Posted by YBNormal07 View Post
    To clarify, since this is a pretty old thread:
    An ECU reset does not require a time period to wait after the battery is disconnected. Just disconnect it, tap the brake pedal, and reconnect it. You are done.
    For maximum affect, after resetting, get on a open surface with no traffic, place the car in 3rd gear, increase throttle, and slowly let up on the clutch while brake torquing the car (don't let it move). The object is to increase boost for a time frame of around 5 seconds. This will maximise your ECU settings such that you will immediately gain a good 20 HP over the "worn" stock ECU settings. The background is much more complex than this, but this does work.
    Uh, won't this burn up the clutch?
  11. #69
    Jul 2014
    kelowna
    has this ever been documented on a dyno?
  12. #70
    Sep 2016
    My name is Austin and I just bought a 2004 wrx with 90k on the motor and the guy that I bought it from modded the car with 1000cc injectors, a 20g turbo, a full exhaust system, and a perrin intake. I want to return the car back to stock and I have most of the parts to get the thing back to stock but the guy put a base tune on the car, meaning that the car is not tuned for the parts and runs like garbage. I was just wondering how to get a stock tune either with a access port, get it pro tuned back to stock or do a ecu swap if that could work. I want to get my car back on the road so I can drive it.
    Please Help!
  13. #71
    lit fam XJman's Avatar
    Feb 2015
    At work
    Put the stock parts on, tow it to a performance shop and have them tune it
    All? NO ALL!
  14. #72
    Oct 2005
    Late Devonian
    If it has an accessport installed you can use that to revert it to stock. If it isn't already installed it isn't worth it but you should be able to get a stock map to load.
    You can use an openport cable and ECUFlash for much less than an accessport. It shouldn't be hard to find a stock '04 map online. The instructions for reflashing are in the tuning section stickies.
