Results 1 to 13 of 13
This is a discussion on DIY Oil & Filter Change within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; i was bored...very bored. tech's @ velozt.com...
    TRM
    TRM is offline
    Registered User TRM's Avatar
    Oct 2003
    Pennsylvania
    tech's @ velozt.com
    Dec 2003
    Pittsburgh, PA
    Re: DIY Oil & Filter Change
    tech's @ velozt.com
    Nice job as always man, I'm sure that will help out some first timers.
    -st
    Moderator smorris's Avatar
    Mar 2002
    Avon, Ohio
    Thanks for the write up. Moving to Tutorial Forum.
    Steve - Avon, Ohio, USA - Moderator - Fun Drives and North Central States
    The Morris Garage
    2008 Outback 2.5XT Ltd __2002 WRX Wagon __ 1958 MGA Roadster __ 2008 smart Cabrio __ and a few scooters...
    Bugeye Mafia #338
    TRM
    TRM is offline
    Oct 2003
    Pennsylvania
    Doh! i need to read the sections more thoroughly.
    thanks.
    Registered User chad1043's Avatar
    Nov 2005
    Holland
    2006 Wrx Tr?
    Does these tuutorial work for 2006 WRX TR?
    Hawk-Eye alliance #1043
    My Car... 2006 Subaru Impreza WRX TR
    My Motorcycle... 2005 Kawasaki ZX-10R
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    Pretty much anything on the engine will be the same. Suspension and brake parts are different between STi and WRX, but still all the same basic mounting points (except the brembos).
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
    Jan 2008
    Oregon
    Is there a specific reason that you would use ramps instead of jacking the car up other then convenience? I have a friend who warned me about using a jack with a Subaru. I don't see why using a jack and jack stands would be an issue when doing an oil change.
    Thoughts or comments?
    Thanks!
    Resident meany-rator 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Quote Originally Posted by cjhudson101 View Post
    Thanks!
    Because the jacking points are hard to get to and if you use improper jacking points use damage the car. Ramps are easy to use, safe and cheap.
    Apr 2007
    8000' up in Colorado
    As somebody that has jacked up their car, I'd highly recommend getting ramps. I've worked on cars for about 15 years and the Subaru is the toughest one to find good jacking points on. As previously said, you can easily damage the car if you don't know what you're doing. There's only a couple of spots that are strong enough to withstand the force of the jack or jack stand.
    Scott
    Jan 2008
    Oregon
    I did my oil change last night, and holy crap does that oil pour out fast...
    I got a little splash on the garage floor but it wasn't too bad. My old tercel was definitely allot easier to change the oil on.. lol
    Any tips other then not using the hollow plastic oil pan since it barely kept up with how fast the oil came out of the pan.
    --Chris
    Jul 2008
    SoCal
    How many quarts of oil do you put in a 07 wrx?
    Thanks / Tim
    Jul 2007
    link broke
    Sammich Makin' Princess Leia wrxtreme06's Avatar
    May 2007
    orlando flawduh
    Quote Originally Posted by juventus1983 View Post
    link broke
    its from 2003. what did you expect?
    desiree
    06 impreza wrx tr
    : cobb stage II - protuned by STi_Mikey!
    hawk-eye alliance #11:11 //
    wingl3ss @ll!ance #17 // lvl 80 N.E.R.D.
    facebook
