How to change your sparkplugs - Page 8
Page 8 of 18 FirstFirst 1234567891011121314151617 ... LastLast
Results 106 to 120 of 259
This is a discussion on How to change your sparkplugs within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; I just ask the question because another user had stated that they break apart in the combustion chamber which seemed ...
  1. #106
    Registered User gda03subaru's Avatar
    Mar 2007
    Austin, Texas
    I just ask the question because another user had stated that they break apart in the combustion chamber which seemed highly unlikely to me. It is not that hard to gap iridium plugs just takes a little more time
    HAVE YOU SEEN ME?
  3. #107
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    I had heard rumours of this too, now that you mention it. But I wasn't able to ever verify the truth of the matter. After all...what is going to break in the combustion chamber? The lip? The 'trode? Seems unlikely to me. Maybe it occurs under extreme build conditions? I don't know. It just seems unlikely to me. I've cracked a few plugs before, and you know it when it happens. My bet is the breaking occured due to inproper cams/valve clearance...and this is not all that uncommon.
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
  4. #108
    Mar 2007
    Austin, Texas
    True i have also heard of improper clearance issues. But on a stock motor like 2/3 of the subys are and for that matter the rest of the other makes and models. Engines that have never been torn apart and or the head removed. It just didnt add up to me. The only thing i could think off was cracking the plug before installing it, either the electrode or the porcelin, and not being competent enough to realize it before hand.
    HAVE YOU SEEN ME?
  6. #109
    Registered User lucky's Avatar
    Mar 2007
    spartanburg s.c
    Reinstall all the pieces you have removed. Hooking up the battery last.
    Check your spark plugs for unusual color- lot's of good sites explaining the different colors and conditions.
    You have effectively reset your ECU by disconnecting your battery, which means the Advanced Multiplier (AM) is set back to 8, you want it to get to 16. You can do this quicly by gently driving (no boost) until you have a place you can get into 3rd gear- accelaerate slowly, left foot braking (puts load on) keep boost at ~ 2-3 psi for ~ 20-30 secs and it should be there. Ofcourse if you have a Delta Dash, you can tell for sure.
    Happy driving.
    Big Sky
    just disconnecting battery resets computer and putting load on it just hold brake down for 20 2 30 sec at 2 2 3 psi im about 2 change my spark plugs thanx for reply
  7. #110
    Jul 2001
    Plains of Eastern Montana
    yes- disconnecting the battery will reset your computer to a Advanced Multiplier of 8- this is right in the middle of the AM range- 1 being "unhappy", 16 being very "happy" (thus more timing and performance).
    A little "trick" to get the AM up to 16 quickly is doing as described- if you skip this "trick" no biggie- as the computer learns (and is "happy") it will move the AM towards 16
  8. #111
    Mar 2007
    spartanburg s.c
    it will actually learn it its self thanx for reply by the way
  9. #112
    Registered User silver03's Avatar
    Jul 2003
    10000 Lakes
    very helpful thread
    I just finished pulling stock plugs (65k) for the iridium one step colder (tbe & cobb stage 2). The "game" is figuring out which extensions and swiveling pieces will get the job done. I got the laptop in the garage with the wireless and just kept scrolling thru the tutorial until job done. The iridiums came gapped just under 030, so I left him. I havent test driven yet, but it did start up fine and idle smoothly for several minutes before I shut it down. Thanks for the tutorial Big Sky!
  10. #113
    May 2007
    re: the swivels
    for anyone having difficulty with the swivel extensions here's a nice little trick i picked up. wrap the part that actually swivels in a wee bit of electrical tape to provide some resistance to the flip floppity nature of the little imps. i always use 3m super 33 because it doesn't leave a residue and because its made out of angels.
    hope that helps a wee scosche
  11. #114
    Registered User wrxlude's Avatar
    Dec 2002
    Your location violates our politics rule
    gonna do it this weekend.
    thanks, BigSky!
    (sucks that we don[t have the pics anymore)
    LET'S GO COLTS!!!
    I have 5 infraction points. What do you have?
  12. #115
    Jul 2003
    PA
    Quote Originally Posted by wrxlude View Post
    thanks, BigSky!
    Opportunity for new pics to be posted???
  13. #116
    Dec 2002
    Quote Originally Posted by YBNormal07 View Post
    something came up that didn't allow me time to change them.
    Weekend after Labor Day weekend I'll do 'em and take pics.
    LET'S GO COLTS!!!
  14. #117
    Jul 2003
    PA
    Kewl....as they say...ttiwwop
  15. #118
    Jul 2001
    pics are showing up for me- not showing up for you guys?
  16. #119
    Jul 2003
    PA
    Odd...the pics are now appearing. I must have looked at this thread when we were having those server issues. Oh well....I guess this thread iswp (is great with pictures).
  17. #120
    Jul 2001
    yeah- we definitely were experiencing a few issues over the last couple of months
