Page 5 of 18 FirstFirst 123456789101112131415 ... LastLast
Results 61 to 75 of 257
This is a discussion on How to change your sparkplugs within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; Yea.. I just downloaded the file and just printed it. Looking over it. Looks like 30K service is: oiil change, ...
  1. #61
    Oct 2005
    oiil change, brake fluid, fuel filter, radiator, air filter and pvc (which does not show in it).
    The spark plugs as you mention is 60K replacement.
    Quote Originally Posted by Big Sky WRX
    Try this thread- it has a link for the scheduled maintainence- the 30,000 one should have been done.
    Service Manual excerpt: Periodic Maintenance
  2. #62
    Registered User turbo_bxr's Avatar
    Aug 2004
    hamilton,oh
    thanks big sky, your write up on this helped me! i did use multiple sockets and even broke one flex, had to get it replaced so it took me extra time to do this. but id say it was 2hrs or less overall.
  3. #63
    Registered User dielectric's Avatar
    Mar 2003
    Palatine, IL
    I did the plug change yesterday. I want to re-emphasize a note that Big Sky made. Use a locking extension on the plug socket. Mine pulled out of the socket, so I had to get in there with some little pliers and pull the socket off the hard way.
    It didn't add a whole lot of time, but it sure aggravated me. I'm off to Sears this morning to buy some better extensions. Never again!
    ribonucleic acid freakout
  4. #64
    Mar 2004
    New Jersey
    Thumbs up
    thanks big sky, this thread helped a ton! i would have made a boat load of mistakes.
    couple of things I noticed with my plug change:
    on my 05 wrx, the battery did not need to be removed. maybe the 04 you have is slightly laid out diff but i got in there ok with the battery in. it was a little tight buy i managed.
    some
    i found a trick to get the socket off the plug you just installed: the first plug i put on the socket got stuck, had to use needlenose pliers to work it out. on the rest, i decided to throw a little spit on the insulator... as a lube... it helps the socket slide off w/o getting stuck in there. hehe, if you've never used spit as a lube before, youre lyin.
    careful with the ratchets and sockets on the passenger side. when they drop they are hard to get, you need a set of needlenose to fish them off the skid plate, that's a real pita
    someone asked which side the black and white plugs go on. for me it "black in back", white by the lights (thats the stupid rhyme i used to remember which wire went on which plug, but it worked)
    last i would say take your time... my first time was about 1:45 or so, but there
    some things you don't want to forget to install if you rush and fock up. next time it'll take me under an hour. thanks man.
  5. #65
    Jul 2001
    Plains of Eastern Montana
    Glad it's been helpful guys
    I'm missing the black and white plug thing though?
  6. #66
    Mar 2004
    New Jersey
    my bad... i think that someone on another thread (sorry I mixed that up, it was getting late, must've thought it was this thread) placed the connectors on the wrong coil pack. which made the car run a wee bit off. so i was just mentioning it for anyone else who might make the same mistake: the black connector (and your photos clearly display this) goes to the coil pack on the back (towards the firewall). white connector goes on the front coil pack by the lights. sorry to be a bit confusing above.
  7. #67
    Jul 2001
    OK that makes sense on the coils- good tip!
  8. #68
    Dec 2003
    Upper Sandusky, Ohio
    I have a few questions. First what size flex sparkplugs socket do you use. I know most everything is metric ,but I couldn't find a metric plug socket. Is it just a 5/8" plug socket? Second question is how do I know if I have platium plugs or not. I haven't changed my plugs yet and my car has about 28,500 miles. The service manual says to change them at 30,000 and I have heard that platiums last about 60,000. I have a turbo back exhaust and a MBC plus a CAI. In the future I plan on adding a uppipe and a UTEC. If I change the plugs now will I have to re-gap them later after the mods? Should I start with about .028 gap for the mods I have? Thanks for this tread it has already helped me alot.
    Tough times never last....Tough people do!!
  9. #69
    Aug 2004
    hamilton,oh
    my latest plugs went bad after 22k miles. i was running to rich with my TBE and thier fuel fouled from hard runs , more boost and power puts more stress on all parts, so service earlier than said.
  10. #70
    Jul 2001
    5/8 " is the one you need
    The platinum plugs call for 60,000 change in the owners manual, I'd at least look at them at 30,000 (and replace while your at it).
    The oe plugs are NGK PFR 6G
  11. #71
    Aug 2004
    hamilton,oh
    buy them anywhere but subaru if possible. 55 bux just for the set. and the STi plugs were 13.55 each or something close to that and i think they were cheaper through advance.
  12. #72
    Oct 2005
    bay area, california
    damn, all that work to change spark plugs? yikes... i miss my acura.
  13. #73
    Feb 2006
    Siren, WI
    To those of you who like the flex sockets...
    What should I buy,
    A set of flex sockets?
    A flex head ratchet?
    I have both 3/8 and 1/4 drive ratchets, being that the flex sockets are for getting into tight spots, would it make more sense to get the 1/4" drive sockets (my 1/4" drive ratchet is about 7" long), or would I be needing more torque?
    Thanks,
    Brian
  14. #74
    Aug 2004
    hamilton,oh
    Quote Originally Posted by SubeN'Siren
    What should I buy,
    Thanks,
    Brian
    well, the back driverside is so hard to get to you need flex heads for everything, and also for when your taking the plugs out because the motor sits a bit lower than the frame and you have to angle it in to get them out right. thier a worthy investment, trust me. and buy craftsman because if you try the back like me, you'll break the 12mm flex.
  15. #75
    Aug 2004
    hamilton,oh
    Quote Originally Posted by turbo_bxr
    btw i didnt use or buy a flex head rachet. thier annoying as hell anyways.
