Page 14 of 18 FirstFirst ... 456789101112131415161718 LastLast
Results 196 to 210 of 257
This is a discussion on How to change your sparkplugs within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; I am ready of stage 2 just need the ap...
  1. #196
    Registered User jcfuzzdog29's Avatar
    Nov 2007
    Paxinos, PA
    Blobeye Syndicate #004
  2. #197
    Wrinklechops
    Quote Originally Posted by jcfuzzdog29 View Post
    Then I would suggest maybe something like this:
    Denso Iridium Plugs for 02 - 05 WRX (1 step colder)
    Under $50 for a set of quality plugs isn't bad.
  3. #198
    Nov 2007
    Paxinos, PA
    Thanks man how hard is it to do the plugs.
  4. #199
    Oct 2002
    The Old Folks Home
    Did mine a few months back...followed this very tutorial. I found it to be fairly easy, once I got a small breaker bar that would fit in to get out the back driver's side plug. You spend most of the time just moving stuff out of the way to get access.
    --Ray
    Proud owner of a N.E.R.D.
  5. #200
    Nov 2007
    Paxinos, PA
    Where did u fine the directions and stuff.
  6. #201
    Wrinklechops
    In this thread, go to page 1 and start from the top
  7. #202
    Registered User ArchangelF16's Avatar
    Jul 2004
    Tokyo
    Quote Originally Posted by lundholm08 View Post
    2004 White WRX (R.I.P.)
    2006 White TR replacement
    1998 V5 Grey STi
  8. #203
    Nov 2007
    Paxinos, PA
    sorry that was funny didnt know asking a simple question was funny
  9. #204
    Oct 2002
    The Old Folks Home
    Don't take offense..people found it humorous because you're asking for directions in a thread that has, well, the directions.
    Simply go to page one of this thread..Big Sky has a great writeup.
    --Ray
  10. #205
    Nov 2007
    Paxinos, PA
    i didnt take offense i jsut didnt relize it was funny that i ask a simple question. he seemed ok telling me to go to the fist page instad of me looking at all of them
  11. #206
    very nice diy..its definitely helpful for everybody....
  12. #207
    Jun 2009
    Thumbs up
    A thanks to the OP for making this thread. I plan on using the NGK plats tomorrow. 144k on my 02WRX and a P0171 code. No record of past maintenance.
    As a side note, after changing plugs xx number of times in EJ25s, I use a spark plug socket with the rubber inside, and a 5" extension. My trick is using a thin layer of electrical tape to keep the socket on the extension together when you pull it out after putting the new plug in. Just enough tape so it keeps the two pieces together and not too much that it doesn't fit in the spark plug hole. These two pieces give me just enough room to get a socket wrench in there, as well as my torque wrench for the 15ftlbs for all 4 holes.
    Also another side note, when you take the bolts out for the windshield washer fluid reservoir, be sure to use anti-seize on them when you put them back in. I can't found how many of my old cars are running around with just one of those two bolts left holding the reservoir on. Same deal for the two bolts that hold the front air duct to the radiator frame.
    Ryan
  13. #208
    Jul 2001
    Plains of Eastern Montana
    ^ good tips- thanks
  14. #209
    Moderator Donkey's Avatar
    Da boonies
    Also I would never use that gapping tool one Iridium or Platinum plugs due to their thin center electrodes. You might break them as that tool applies force to the center electrode. I use one that applies force only to the side electrode.
    Also make sure the harness plugs for the coil pack go back to the same location they came from!
    2002 FORESTER S
    1998 FORESTER S
  15. #210
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    Good tip (no pun intended).
    I usually tape my harness with numbers so I can't forget what position they go to. It's easy to forget once you have them all out (don't ask me how I know...I was 16 once too).
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
