rubber mallet.
hope you're not running x drilled on the street. there have been numerous reports of cracking and failure.
not a good thing!
dR
This is a discussion on rotor replacement within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; Hey everyone, I'm upgrading the rex to slotted and drilled rotors, and I'm havin some trouble gettin the stockers off. ...
Hey everyone, I'm upgrading the rex to slotted and drilled rotors, and I'm havin some trouble gettin the stockers off. I removed the caliper completely from the rotor, and I expected the rotor to slide off, but its not. What else needs to be unbolted to get this thing off??
rubber mallet.
not a good thing!
dR
sucker is on tight...i'll keep whackin away though. maybe I should mention I'm workin on the rear rotors?
p.s. yeah i've heard about the broken rotors...i'm selling the car pretty soon though. don't worry, i've got a new suby project...and you guys are gonna go nuts over itbut thats gonna be a secret for a while, right now its the rotors i've gotta get off
Well after repeated beatings with the mallet, the damn thing won't budge...any ideas?? Its almost like its bolted or welded on or something...very frustrating. Anyways, thanks for the help so far...any further assitance would be much appreciated
ok, I figured it out...there are two separate and smaller holes on the rotor, not the 5 for the wheel studs, but two different holes. tighten a 8mm stud bolt in there...it'll push against the hat ( I think it's the hat, not sure, I'm not too good with terms) and you'll hear a snap sound...then the rotor should slide right off
Yup - that's the way to do it. They're a tight fit, but keep screwing and those suckers will come off.Originally posted by jono
I wish that I had read this thread sooner...the using the smaller screws to pop it off would have been my suggestion.
Matt
WRX-less, now RSX-y!!!
