Headlight adjust
Results 1 to 15 of 17
This is a discussion on Headlight adjust within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; Just thought I would throw this out in case some of you guy's experience my prob. I have a tad ...
    Registered User ShotgunTC88's Avatar
    Nov 2002
    Ky
    Headlight adjust
    I have a tad of "night blindness" and notice that my 03 WRX headlights only cover about 50ft out before things go alittle dark so I adjusted them up to about 70ft by turning the little allen screw inside the left rear corners of the light under the hood.
    Ya might wanna try it, It really helps ya see those sneaky curves
    .02
    Shotgun
    p.s, For other drivers sake as far as blindin em, I had my wife drive her car and we made some passe's under diffiring cond. and it did not blind or seem to cause the "Dim your lights dumbarse" syndrom.<GGG>
    Re-Addicted to WRX tacomaboy138's Avatar
    May 2003
    Irvine, Ca (The Bubble)
    From what perspective is "left rear."???
    2011 SWP WRX 4D
    07 MINI Cooper S... SOLD!
    03 WRX Wagon... SOLD!
    98 Toyota Tacoma...SOLD!
    Jeremy Clarkson has had my dream job.
    Feb 2004
    So Cal
    Smile Headlight Adj
    Can't locate screw? Where is it actually? Can you provide pics?
    Thanks
    May 2003
    if you are looking at the driver's side headlight from the top. The screw will be on the actual headlight housing on the right hand side. It really is the only screw back there i believe [that is actually on the headlight housing], all the rest actually hold the headlight in place.
    p.s. do not strip this screw.
    2011 SWP WRX 4D
    Feb 2004
    So Cal
    Talking
    Thanks! Will try it when I get home.
    Registered User AjIsDope's Avatar
    Aug 2002
    SoCal
    To bring the lights "up" more, which way do you turn it? (I assume clockwise)
    03 Cobra
    566whp/515wtq
    Pics
    & Dyno
    Pics
    Aug 2002
    Virginia Beach, VA
    To what extent is this legal? It would seem that if you turned your lights up to a certain degree, they would become a hazard for other drivers....any validity to this?
    ~Tim
    Aug 2002
    SoCal
    I only need to do this because my car is lowered and the beam does not project as far as it used to.
    May 2003
    it is clockwise to go up.
    It is probably as illegal as driving with highbeams on? So a cop will be just as likely to pull you over if he sees you on the road at night. it is a little more difficult to adjust the fogs...you have to reach [from the front] one screw on the fog lamp assembly [whichever one is different from the other three screws which hold your fog lamp in place] Mine was pretty tight when i adjusted it...
    2011 SWP WRX 4D
    Aug 2002
    SoCal
    I just adjusted my headlights and fogs. The HL adjustment screws you can find by opening your hood, then look in the corner of the engine compartament near them. You will see the head of the screw looking at you. Turn them clockwise and the light beam will rise.
    The fog light adjustment screws are the top left screw for the driver side, and the top right screw for the pass. side when looking from the front of the car. For some reason, the light beam rose as I turned the screw counter-clockwise, opposite of the HL's.
    Nov 2002
    Ky
    ~Tim
    Uh, Let,s talk S.U.Vs and blinding people...............
    Shotgun
    Aug 2002
    Virginia Beach, VA
    Shotgun
    Oh god, don't even get me started! I can't even stand the headlights on my Forester when I'm driving in front of it, let alone an SUV. I'd rather have my corneas burnt out wiht a laser than drive in front of an escalade with HID's
    Nov 2002
    Ky
    I rest my case...
    Shotgun
    May 2003
    what's even worse are the idiots with lifted trucks and SUV's that DO NOT readjust their headlights after their absolutely unnecessary 10" lift w/ 44" Super Swampers...
    2011 SWP WRX 4D
    Nov 2002
    Ky
    UPDATE!!!
    For those of you that did "Dumbo" heres idea of adjusting the headlights.........
    Well, The other night wifey was drivin in front of me and when we got to our desto..She said "Your left headlight is brighter than your right one" And of course I was like, Yea right, I am the all knowing "Mr.Wrench" how dare you downtalk the mighty one with the Gold plated Craftsman wrench (anniversary edition)!!.....LOL!
    Sure enough it was!!
    After a couple of hours of adjusting/havin her drive ahead/ me pullin/switchin bulbs/ runnin Ohm meter/pokin wires/gobbin electric contact grease/takin the WHOLE DAM headlights (yea,bothsides) off and tryin to figure out why the hell one side was brighter for with no discernable difference.....
    It seems (cough,lookin around hunkerin) that if you get ONE of the headlights screw adjuster,s the slightest bit different (Unequal turns as little as a 1/4-1/3) on one side...THAT bulb will reflect ever so slightly different in the headlight body reflector so that it reflects as if it is brighter than the other!!! .....(ala, Bad ground,bulb,short,UFO passover,etc)
    They MUST be within a half turn (at most!) on the adjustment screw with EACH OTHER or you may be feelin as dumbarse as me when you find out!!!........
    This may or may not apply to your particular car but at least check it out before you feel like wifey made me.....LOL!
    .02
    Shotgun
    (yea, but her crosstiching has got missing "X,s" so screw her.<GG>)
