Running Lean
Results 1 to 2 of 2
This is a discussion on Running Lean within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; I have an '02 WRX. My friend put a rather large K&N air filter on it. Now the 'Check Engine' ...
    Jun 2003
    Running Lean
    I have an '02 WRX. My friend put a rather large K&N air filter on it. Now the 'Check Engine' light is on, and it will stall if I give it a lot of gas and then take it out of gear. Subaru Service told me it's code PO171 (system too lean). I'm assuming that if I can up the fuel, everything will be OK. Right? If so, what's the easiest way to do that?
    Registered User is2scooby's Avatar
    Jun 2002
    Honolulu, HI
    Put the original air filter back on.
    I have run 12.75 @ 105+ on the stock air filter in the stock box (minus the resonator).
    Aloha, Richard...
    Retired Moderator
    TXS Stage 4 UTEC + TMIC + JoeP
    12.75 @ 105.67mph - 1.74 60'
