up-pipe leaks!!!arghhhhh
Results 1 to 6 of 6
This is a discussion on up-pipe leaks!!!arghhhhh within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; Just a warning to those who tackle this job, make sure you use some good sealant...
    Feb 2003
    alabama
    Registered User pityr's Avatar
    Oct 2002
    Beaverton OR
    sealant? why would you use sealant? Stock gaskets are more than enough.
    No one will truely be free until nerd persecution ends.
    Feb 2003
    alabama
    apparently not.
    Apr 2003
    CT
    Originally posted by ttownrex
    apparently not.
    If you install it correctly they are! Try re-tourqing the bolts down
    '12 WRB Sedan
    Mar 2003
    Chandler, AZ
    I always thought that leaks were the result of the pipe and installer.
    Steve McQueen's got nothin' on me...
    I'll take you back, west of Pleiades...
    Nov 2003
    Dayton Ohio
    Make sure you follw the correct torqing sequence when reassembling it.
    I have a perrin uppipe, check out their instructions on the web.
    WHen I first did it it leaked cause I used the subydude gasket kit and one of them cracked in half, all the others for the up and downpipe are still sealing 4 months later.
    FOr the leaker I just reinstalled the stock steel gasket (the used one) and have been leak free ever since.
    If you don;t follow the correct torque sequence you'll be getting leaks.
    Your Friendly neighborhood Antimullet
