P0011 Camshaft Position - Timing Over-Advanced (Bank 1)
P0012 Camshaft Position - Timing Over-Advanced (Bank 2)
P0030 Front O2 Sensor Heater Control Circuit
P0031 Front O2 Sensor Heater Control Circuit Low
P0032 Front O2 Sensor Heater Control Circuit High
P0037 Rear O2 Sensor Heater Control Circuit Low
P0038 Rear O2 Sensor Heater Control Circuit High
P0068 MAP/Barometric Pressure Circuit Range/Performance
P0101 Mass Air Flow Circuit Range/Performance
P0102 Mass Air Flow Circuit Low Input
P0103 Mass Air Flow Circuit High Input
P0107 MAP/Barometric Pressure Circuit Low Input
P0108 MAP/Barometric Pressure Circuit High Input
P0111 Intake Air Temperature Circuit Range/Performance
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0121 Throttle Position Sensor Switch “A” Circuit Range/Performance
P0122 Throttle Position Sensor Switch “A” Circuit Low Input
P0123 Throttle Position Sensor Switch “A” Circuit High Input
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
P0128 Coolant Thermostat
P0129 Atmospheric Pressure Sensor Circuit Range/Performance
P0131 Front O2 Sensor Low Voltage
P0132 Front O2 Sensor High Voltage
P0133 Front O2 Sensor Circuit Slow Response
P0134 Front O2 Sensor Circuit No Activity Detected
P0137 Rear O2 Sensor Circuit Low Voltage
P0138 Rear O2 Sensor Circuit High Voltage
P0139 Rear O2 Sensor Circuit Slow Response
P0171 System too Lean
P0172 System too Rich
P0181 Fuel Temperature Sensor “A” Circuit Range/Performance
P0182 Fuel Temperature Sensor “A” Circuit Low Input
P0183 Fuel Temperature Sensor “A” Circuit High Input
P0230 Fuel Pump Primary Circuit
P0222 Throttle/Pedal Position Sensor Switch B circuit low input
P0223 Throttle/Pedal Position Sensor Switch B circuit high input
P0244 Turbo Wastegate Selenoid “A” Range/Performance
P0245 Turbo Wastegate Selenoid “A” Low
P0246 Turbo Wastegate Selenoid “A” High
P0301 Cylinder 1 misfire detected
P0302 Cylinder 2 misfire detected
P0303 Cylinder 3 misfire detected
P0304 Cylinder 4 misfire detected
P0327 Knock Sensor 1 Circuit Low Input
P0328 Knock Sensor 1 Circuit High Input
P0335 Crankshaft Position Sensor “A” Circuit
P0336 Crankshaft Position Sensor “A” Circuit Range/Performance
P0340 Camshaft Position Sensor “A” Circuit (Bank 1)
P0345 Camshaft Position Sensor “A” Circuit (Bank 2)
P0420 Catalyst System Efficiency Below Threshold
P0442 Evaporative Emission Control System Leak Detected
P0447 Evaporative Emission Control System Vent Control Circuit Open
P0448 Evaporative Emission Control System Vent Control Circuit Shorted
P0451 Evaporative Emission Control System Pressure Sensor Range/Perf.
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P0453 Evaporative Emission Control System Pressure Sensor High Input
P0456 Evaporative Emission Control System Leak Detected (small)
P0457 Evaporative Emission Control System Leak Detected (Fuel Cap)
P0458 Evap. Emission Control System Purge Control Valve Circuit Low
P0459 Evap. Emission Control System Purge Control Valve Circuit High
P0461 Fuel Level Sensor Circuit Range/Performance
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel Level Sensor Circuit High Input
P0464 Fuel Level Sensor Circuit Intermittent
P0483 Cooling Fan Rationality Check
P0502 Vehicle Speed Sensor Circuit Low Input
P0503 Vehicle Speed Sensor Intermittent/Erratic/High
P0506 Idle Control System RPM Lower Than Expected
P0507 Idle Control System RPM Higher Than Expected
P0512 Starter Request Circuit
LinkBack URL
About LinkBacks
