Timing Belt and Water Pump Replacement - Page 3
Page 3 of 8 FirstFirst 12345678 LastLast
Results 31 to 45 of 115
This is a discussion on Timing Belt and Water Pump Replacement within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; Look at post 26. Push where the arrows show and I use a small metal ruler. That's the way I ...
  1. #31
    Registered User section9's Avatar
    Jun 2005
    AK49
    Look at post 26. Push where the arrows show and I use a small metal ruler. That's the way I do it. It looks like you're supposed to push or pull with a certain amount of force, but I just wing it. It seems to work fine. The whole process is actually pretty easy. Just take your time and go step by step.
    Batmobile: 2002 WRX wagon RIP
  3. #32
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    Thread stuck! Nice write-up
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
  4. #33
    Registered User T.J.'s Avatar
    Oct 2002
    on a boat...
    Thumbs up
    Great write-up! Lots of helpful tips! I used it successfully this weekend. Thanks!
    A couple of things I can contribute:
    1. Inspect the Hydraulic Belt Tensioner as you are taking things apart. Mine was leaking fluid from the seal and needed to be replaced. Another $115. I think this is fairly common. You might just purchase it beforehand and then return it later if you don't need it. That way you don't end up running to the dealership in the middle of the operation like I did.
    2. As I worked the belt onto the gears going counter-clockwise from the crank (this technique seemed to work really well), I re-installed the belt guides as I went. I figured they would help keep the damn belt from jumping teeth after I got it on a gear where I wanted it. Worked great as far as I can tell.
    Thanks again Section9, T.J.
    200,000 mile club.
    Old Irish adage: "Do not resent growing old. Many are denied the privilege."
  6. #34
    Jun 2002
    Michigan
    pics?
    Exactly what I was looking for, except the pics seem to have been obliterated... Anyone know what happened?
    Nice write up, tho!
  7. #35
    May 2007
    Cedar Park, TX
    Awesome write up....Just finished mine minutes ago....T-Belt, Water Pump, Idlers, and Tensioner...went ahead and changed the oil and the plugs while I was at it. 102K on the girl and another 100K to go!!
  8. #36
    Jun 2008
    Thumbs up Mad props!
    Thanks Section9!
    I don't own a Subie rex, but my buddy's 04 needed the timing belt/waterpump/plugs all replaced and your writeup allowed us to do it! Just to give you some background, he's not particularly car savvy, and I've been modding cars/trucks "garage DIY style" for a few years now. Anyway, I've never seen a WRX's hood open in person until yesterday, (aside from some nice STi's at shows), never been cursed with a car that has a timing belt (I'm thankful for chains!) and we successfully performed all the scheduled 105k maintenance. At a leisurely pace it took us about 8 hours. THANK YOU! Excellent writeup! You saved my buddy ~$800. I had to register just to tell you this.
    regards from the PNW,
    Andrew
  9. #37
    Registered User Soulrebel's Avatar
    Jun 2008
    Philadelphia
    Question Mechanic needed in Philadelphia
    Hey Guys,
    I have a 2003 WRX ATM, the to cam gear broke and I need it replaced, I have no clue if the any of the valve were bent as the vehicle has not been turned on since the gear broke. I need a good mechanic in Philadelphia who is reasonable, does anyone know a good mechanic does not have to be a dealer.
    Thanks
    Soulrebel
  10. #38
    Oct 2002
    on a boat...
    Quote Originally Posted by Soulrebel View Post
    Hey Guys,
    Thanks
    Soulrebel
    You might try asking in your local forum: Tri-State - ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
    Good luck, T.J.
    200,000 mile club.
  11. #39
    Jun 2008
    Philadelphia
    Thanks
    Thanks TJ, I will try that
  12. #40
    Jul 2008
    MN
    Replace crank seal
    Nice write up on replacement of belt and water pump.
    Wondering on how to get at crank seal?
    I have the timing belt off and looking to replace the crank seal.
  13. #41
    Nov 2008
    Central NJ USA
    Great writeup! I am going to do my timing belt soon.
  14. #42
    Jan 2003
    San Jose, CA
    parts needed/recommended?
    I know this is an old thread and all, but it's finally time to do this on my wife's 02 wagon. On a car where none of the following parts have been replaced already, is this a good list of parts I should be replacing when doing the timing belt? Is anything missing? Anything here that really doesn't need to be? Do I need to replace all the idlers?
    Parts:
    Timing Belt
    Tensioner (if yours is leaking)
    Upper Idler
    Lower Idler
    1 Upper Idler (small bearing. 31mm O.D.)
    1 Lower Idler (sprocket with bearing.)
    Water Pump
    thermostat
    a/c belt
    alternator belt
  15. #43
    Oct 2002
    on a boat...
    I didn't replace the idlers or idler bearings. I don't know if that is common. I suppose it wouldn't hurt anything though.The rest looks good.
    Good luck, T.J.
    200,000 mile club.
  16. #44
    Oct 2008
    timing question
    Just to clarify, before I remove my old belt I should make sure my cam & crankshaft marks line up? Will this also line all the other marks up too or is it ok if those ones are off?
    sorry for my noobiness
  17. #45
    Jun 2005
    AK49
    No you don't. As soon as you take the belt off, the pulleys are going to spin. But I did it to see how the marks lined up with the original belts.
    You're welcome everyone! Sorry it's been so long, but I'm glad I could contribute.
