Results 1 to 6 of 6
This is a discussion on 02 wrx temp rising within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; I just got my car back from popping in a new engine and switched from a unichip to accessport. Anyway, ...
    Jul 2007
    TX
    02 wrx temp rising
    I just got my car back from popping in a new engine and switched from a unichip to accessport. Anyway, I drove it 50mi. or so..turned it off and came back probably 15min later and was able to drive a few blocks before my temp gauge started to significantly rise to an unacceptable level. Normally I'd check the hoses and thermostat but I just got the car back like 1hr ago. The only thing I can think of is that I put the A/C on too high and quickly...I'm gonna check it out after the sun goes down. Any ideas besides checking the above mentioned would be great.
    vincere est vivere
    Registered User wait3's Avatar
    Feb 2007
    MT
    radiator flush
    If you have a lot of miles on your 02, a radiator flush could be in order, although if it's just starting to do this with a new engine... probably not the radiator.
    Quote Originally Posted by Dataminer View Post
    Burp the cooling system and check coolant level.
    Before you got it back 1 hr ago the motor was out of the car. Check hose connections and see if the Tstat is opening anyway. You'll pull the cap to burp so why not?
    Irrelevant, it would make no difference. There's no such thing as too high or too quickly for the AC.
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    +1 on all these...plus the obvious: check your coolant level, look for leaks, and (yes, I've seen it before) make sure all coolant lines are plumbed correctly.
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
    Jul 2007
    TX
    Problem solved. Thanks for all the input -- appreciate it.
    Low coolant, Burped, Fan wiring loose/not plugged in at all.
    vincere est vivere
    Registered User wrxlude's Avatar
    Dec 2002
    Your location violates our politics rule
    I'm not a mechanic, but that was gonna be my guess.
    Congrats on 'getting her well' again.
    LET'S GO COLTS!!!
    I have 5 infraction points. What do you have?
