Results 1 to 7 of 7
This is a discussion on 2002 wrx with sluggish problem within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; Hi my question to everyone is i have a 2002 wrx with an aftermarket blow off valve cold air intake ...
    Registered User barrywrx's Avatar
    Apr 2007
    evans mills ny
    Unhappy 2002 wrx with sluggish problem
    Hi my question to everyone is i have a 2002 wrx with an aftermarket blow off valve cold air intake and all of a sudden it is not sounding right and my wrx seems to have lost some of its power, it is sluggish. Does anyone know what might be the problem with it. The blow off valve is still working but know sound and the cold air intake i cannot hear it taking in air. the weather just warmed up in this area and my car has 66 thousand miles could the weather play a part in this
    Registered User Needles's Avatar
    Nov 2002
    Long Island N.Y.
    First take off the aftermarket blow off valve,and the cold air intake.There no good for the WRX.Then read all the FAQ's before you mod your car.
    Stg 2 06STI
    02/04 WRX MSPT Tuned - 18g(DEAD)
    "Never go in against a Sicilian when death is on the line!"-Vizzini
    Mar 2007
    NY
    Quote Originally Posted by Needles View Post
    Hawk-Eye Alliance #181
    Registered User project_skyline's Avatar
    Mar 2006
    Silt, Colorado
    Do what they said and also clean your MAF sensor its probably dirty.
    Registered User koogxone's Avatar
    Mar 2007
    The Best Coast
    your MAF sensor is the little black thing with wires coming out of it on top of the cold air intake. unscrew it and put it in a plastic bag with brake cleaner and shake it up and screw it back on
    if you want an intake, get one that won't mess with your MAF sensor without a tune.. like an SPT intake. most other aftermarket intakes will screw your air/fuel ratio up without a protune.
    -kyle
    bugeyemafia#126
    VF39'd, Bailey-tuned! 280.07whp 250.05wtq
    Apr 2007
    evans mills ny
    thanks guys i will use your advice
    Moderator   Sasquatch's Avatar
    Apr 2004
    Southeastern PA
    Exclamation
    Do not use brake cleaner on the MAF or put into a bag and shake to clean. Have a look at this thread to see how to clean the MAF safely: $5 and 5 minutes to a better running car :)
    Moving to Maintenance, service, troubleshooting, and basic repair
    Moderator for: Aftermarket Vendor & Installer Review / Detailing Forum / Engine Modifications / Exterior & Appearance
    New Member Hangout / Off Topic / Tri-State
    Mods & Pics
