On the defroster trim panel, passenger side, right in front of the airbag, look for the first defrsoter slit in the panel and press on it next to the windshield. You will see the corner of the panel stick up a little bit. You can then stick a screwdriver under it and start to pry it up:
[IMG]http://wrx.****nogs.com/procedures/defroster_panel_1.jpg[/IMG]
Once you pry the end up, slip a finger under it and lift it up. The first clip will release. Then just basically slide your hand to the left to continue releasing each of the (6) clips holding it on. The last clip on the driver's side will tend to bind, but just go ahead and pull it up as straight as you can and it will release:
[IMG]http://wrx.****nogs.com/procedures/defroster_panel_2.jpg[/IMG]
LinkBack URL
About LinkBacks
