CEL P0457 Madness, 2005 WRX
Results 1 to 9 of 9
This is a discussion on CEL P0457 Madness, 2005 WRX within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; Hey guys, been a long time since I've posted on here. I am starting this new thread because anytime I ...
    Registered User 05BlackBeauty's Avatar
    Feb 2007
    C-Reach Strong Isle
    Cool CEL P0457 Madness, 2005 WRX
    Hey guys, been a long time since I've posted on here. I am starting this new thread because anytime I search for an answer I cant find anything pertaining to a 2005. My car is a 2005 WRX and I keep getting a trouble code for the evap system (either fuel cap loose/off, or small evap leak). Luckily I have the accessport so I can diagnose and clear the codes, however I am tired of it coming back every so often (when I highway drive I can get the car to cycle through the diagnosis test and it triggers the CEL). I have taken several steps in an attempt to diagnose the issue myself and Ive been unsuccessful thus far. I have replaced the gas cap with a new OEM Subaru part, I have checked all hoses and fittings connecting to the Purge Control Solenoid valve next to the intake manifold in the engine compartment, Ive even pulled the charcoal canister to inspect for split/cracked hoses and to check the pressure control solenoid mounted above. I modded the car about 8 years ago (Walboro fuel pump included), and never had this issue until about a year and a half ago. This is driving me mad as I keep my car meticulous and Im also due for inspection in about a month so I need to make sure the code doesn't keep re-occurring. The only other information I have related to this issue is that I can pick up on a faint scent of fuel when I am near the fuel door/passenger side rear area of the car. I understand that there are several moving parts involved in the evap emissions control system and I am fairly certain of the ones that I have ruled out so far. I can see that a good amount of people have experienced the same issues with their WRX. Any insight or suggestions are welcome Thanks in advance!!
    -Rob
    OBP 05 WRX sedan, Big Evo III 16G, STi 565 injectors, HKS S-type FMIC, HKS super mega flow intake, Walbro FP, Helix catted DP, HKS UP, SRS catback and so much more.....
    Water.....sometimes waves rqjoe's Avatar
    Feb 2015
    Ohio
    Sounds like a duplicate of a problem I had on an old 2000 Regal. Mine ended up being a rusted-through fuel-fill neck/pipe just behind the plastic when you open the fuel door. I RTV'd it once but that didn't hold long and eventually I had to have the filler pipe replaced.
    - Al Stewart
  5. #4
    Feb 2007
    C-Reach Strong Isle
    All the lines and T-splicing routed to the Purge Control Solenoid near the intake manifold are intact. Might look at the filler neck though conisdering I live in the rustbelt and havent done so yet
    Sent from my SAMSUNG-SM-G890A using Tapatalk
  6. #5
    OK then yes it's worth a look at the filler. I've not lived in the rustbelt in ages and have lost the ability to even suspect rust as an issue out here. Sometimes there are even physical clogs (spider webs etc.) that may trigger the CEL too. Look for anything unusual.
    Oh, about the blue T: Mine had a crack at the T itself and it was just barely visible. I had to look closely. I'd not have guessed it's anything to do with the purge valve but it was after all. No matter where you are looking I'd have a patient second look.
    - Al Stewart
  7. #6
    Feb 2007
    C-Reach Strong Isle
    Sounds worth a second glance....thanks man
  8. #7
    Feb 2007
    C-Reach Strong Isle
    Alright Ive traced an issue to the fuel tank itself. I removed the plastic safety cover for the filler neck and everything appears to be A Ok there upon inspection. However I did notice caked up fuel on the upper part of the tank. I opened the access hatch in the trunk for the fuel pump and low and behold there is grimed up fuel on top of the tank. Im thinking the gasket where the pump/sending unit seats to the tank may have taken a dump is causing vapor leak from the tank, hence the raw fuel smell every now and again. Its an easy swap and a relatively cheap part so I think im gonna go for it. I recall reading somewhere a faulty gasket could cause this code to appear. Sound legit?
  9. #8
    Feb 2015
    Ohio
    Yeah, any leak in the tank cavity can cause that code. Leak downstream of the pump (low fuel press) woud be diff code though. Glad u found it. I have had fuel pumps go in several vehicles but never that gasket.
  10. #9
    Feb 2007
    C-Reach Strong Isle
    Wound up getting the gasket, pulling the fuel pump and cleaning that all up and reseating it. So far so good....no more smell of gas fumes upon fill-up
