Clutch?
Results 1 to 10 of 10
This is a discussion on Clutch? within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; 03 wrx every now and then if I get on it my rpms go up fast and I get no ...
    Nov 2014
    Clutch?
    03 wrx every now and then if I get on it my rpms go up fast and I get no power. Clutch slipping? How ever it seems if I turn the car off and back on its fine. Input would be appreciated
    Nov 2014
    It does have a small exhaust leak before the muffler if that mattera
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    An indication that your clutch is going is that you'll hear the engine rev really fast when you push the gas pedal down, and the car won't accelerate at all - the tack needle will shoot up the dial with no increase in speed. Also, not the best idea to do this too often, but if you are in top gear and floor the pedal, your car should accelerate evenly. If not, that is also an indication of a slipping clutch. Is this your stock clutch?
    Nov 2014
    I get acceleration just very little and yeah the rpms shoot up
    Nov 2014
    Thanks. Just wanted to make sure before I order a new clutch kit
    Nov 2012
    Right, I didn't literally mean it won't accelerate at all, but rather the car won't accelerate commensurate with what you would expect (or what is normal) for that gear/throttle pressure. It sounds like it is slipping. What mods/miles are on your car?
    Nov 2014
    Aftermarket exhaust and rims. There's 130k on it. I just for the car like 3 months ago
    Nov 2014
    Found
    Nov 2012
    Well 130K is a fair amount of miles for a stock clutch (especially if driven very spiritedly). Sounds like you might not know if it is stock or not, or what was done to the car before you purchased it (not intended to offend you in any way whatsoever). Bring it into a mechanic and have them take a drive. A slipping clutch is very obvious.
    Nov 2014
    Ok thanks... yeah I jumped on buying it. It's hard to find bugeyes
