Jacking points to lift 2 wheels at once
Results 1 to 10 of 10
This is a discussion on Jacking points to lift 2 wheels at once within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; What is the best way to jack up 2 wheels at a time for changing whells quickly for autocrossing? Where ...
    Jun 2005
    Dayton, Oh
    What is the best way to jack up 2 wheels at a time for changing whells quickly for autocrossing? Where are the preferred jacking points?
    The front one is pretty easy. This is assuming you have a floor jack, you can slide it from under the front of the car to this metal piece (not sure what its called but if you look under the car its right after the plastic skid plate) and it will jack up the front of the car. I havent jacked the rear, but I remeber reading that some people use the differential as a jack point, but im not sure if I remember that correctly.
    May 2005
    Phillytown, PA
    You can use the rear diff as a jack point.
    Dec 2005
    Clemson,SC
    For autox, I change one side at a time. I just use the front pinch weld. If you get the metal plate thing that looks like a C, it will fit over the pinch weld so you don't mangle it. Just use the weld as far as you can away from the front tire, but not on the plastic. That lifts the entire side of my car up front and rear at the same time. You don't have to have the C block, but it's nicer.
    Registered User Kush's Avatar
    Mar 2006
    Westchester, New York
    Quote Originally Posted by felo3769
    Crossmember. But NOT the radiator support, I've heard of people thinking one was the other...bad things ensued.
    New England F4
    www.OddTopic.net - my pet project, come say hello!
    '02 BUGEYE
    "One's level of fear is directly proportional to their preparedness for it's source"
    -Me
    DO A FRIGGIN SEARCH!!!
    Registered User Bfarm's Avatar
    Jan 2005
    HHI SC
    Quote Originally Posted by clemsonscooby
    Clemsonscooby (I'm a CU Alum ) do you have a link to where you bought the C Block for the pinch weld? Is it just a general use c block for jacks or what?
    I had a little trouble with this myself the other day prepping for an AutoX. The rear diff worked fine but the front crossmember was a bit too far back for my POS jack. I'd like to use the pinch welds but didn't feel comfortable just putting the jack right onto it.
    Thanks,
    BFarm
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    Using a floor jack, you can easily lift the entire side of the car up by using the jack points on the frame at the side of the car, just behind the front wheels (weld pinch points). This works for STi, WRX, and Legacy.
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
    Q RayfieldsWRX's Avatar
    Oct 2002
    The Old Folks Home
    Quote Originally Posted by YBNormal07
    Yep, this is the way that I do it.
    --Ray
    "Bro ima get Bimota BB3 because expert. My parents have 911 turbo but awd won't let me launch, ima get 962 twin turbo Group C bro." -- SD_GR
    2013 Subaru BRZ Limited
    2002 Subaru WRX Bugeyebrid Wagon -- SOLD
    2002 Subaru WRX Sedan -- SOLD
    Registered User VVVV's Avatar
    Sep 2003
    Denverish
    Quote Originally Posted by Bfarm
    Thanks,
    BFarm
    I drive up onto some 6" long 2x4 pieces that I use for wheel chocks. That gives enough room to fit the jack under the skid plate and reach the front crossmember. I don't like raising one side at a time because the stock endlinks are POS and will bend if you're not careful. If you have aftermarket endlinks, then go ahead.
    Jul 2003
    PA
    Quote Originally Posted by VVVV
    Good point...watch your end links when jacking up from the side...I eyeball mine everytime!
