coolant explosion leak
Results 1 to 13 of 13
This is a discussion on coolant explosion leak within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; So three days ago I changed my timing belt water pump etc. Since then I have had zero issues until ...
    Mar 2013
    Greenville, SC
    So three days ago I changed my timing belt water pump etc. Since then I have had zero issues until tonight. The. Car was smoking under the hood but not over heating. Popping the hood it smelled like hot coolant and there is coolant visibly all over the underside. Of the hood close to the radiator cap and overflow tank. My guess is the line running in to the overflow since it (the overflow) keeps running low. The other two caps have a good level consistently when checked and I see no visible cracks or leaks in the lines running along the top of the radiator. Any ideas why I have coolant spewing under neath the hood in that area. And to double check there are no o rings on the insert line for the overflow right?
    Registered User scoobaru03's Avatar
    Dec 2009
    D.C urea, Maryland
    Pressure check the coolant system see where its leaking from
    2003 Impreza WRX Sport Wagon
    "I wouldn't want to belong to a club that would have me as a member." - Groucho Marx
    Is it fast? I don't even know if its street legal. O.o (IROC-Z)
    The overflow is not under pressure and there is no clamp necessary for the line to the white plastic container.
    Nov 2009
    Sounds like the radiator cracked. Common problem. Rev the motor with the hood open. If the radiator is cracked it will spew out fluid.
    Oct 2005
    Late Devonian
    Quote Originally Posted by oguitar View Post
    +1 - timing belt is probably coincidental.
    Aug 2013
    Alberta canada
    Did we find out A solution to this problem? Because I am having the same problem as of last night
    Oct 2005
    Late Devonian
    Quote Originally Posted by Boardbikeandride View Post
    Regardless of what the OP's problem ended up being, the same advice applies to your car. You need to get it pressure tested to see where it is leaking unless you can see where it is coming from more easily.
    Mar 2013
    Greenville, SC
    it turned out to be a crack in the top of the oem radiator on the middle driver side where the plastic and metal meet. I found this out while going to go get the items I needed to do a compression test. I knew I had a leak as you can see in the op but it was not a severe enough loss of coolant to affect a short drive. But on that drive the fissure became worse and the cars temp crept up and I popped the hood and was able to see it. Not the best way to find your leak but I got lucky and didn't harm the engine. I recommend the compression test.
    Aug 2013
    Alberta canada
    Quote Originally Posted by bmoose View Post
    Aug 2013
    Alberta canada
    I just found a hole in the top hose that comes from my rad to my engine, could that be my problem? My engine does not over heat on my temperature gauge, but she definitely smokes heavily all the sudden
    Yes a hole in a coolant line is a problem. Get it replaced. Park the car meanwhile.
    Oct 2005
    Late Devonian
    About how mine went too.
    Oct 2005
    Late Devonian
    After that, refill from the upper reservoir then fill the overflow to the high line. Start the car and allow it to come up to full operating temperature for a few minutes with the passenger heater on hot and the fan on high. Turn off the car, allow to cool, and refill the top reservoir and the overflow.
