If I recall correctly. That hose is connected to your boost solenoid.
I'd not drive it or just not go into boost until it's fixed.
Best remedy is a new turbo inlet hose. Have fun.
This is a discussion on Broken hose? Help! within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; Hello everyone, Can someone help me figure out what this is and give me an idea on repair/replacement costs? I ...
Hello everyone,
Can someone help me figure out what this is and give me an idea on repair/replacement costs? I attached pictures because I don't know how to explain what I am looking at. The hose is located near the base of my air intake. Somehow the hose snapped off. I am certain this happened when I last took it to my mechanic. When I confronted him about the hose, he pretty much blamed me which is BS cause I would have known... anyways - that's a whole other deck of cards...![]()
From what I can tell, the piece is plastic but I can't see how far it goes down or what else it is connected to because the motor is in the way. I've circled the problem in RED. Let me know if I can provide any other clarification and I will do my best. Pics below and thanks ahead of time.
2006 Subaru Impreza WRX TR
Do you have boost leaks? Maybe you can buy just that section of pipe that might come with that piece of plastic, and all you have to do is plug the hose in again. Maybe cost around 100 bucks from subaru parts because dealers parts are ridiculously expensive
Hes not gonna have a boost leak, hes gonna have a massive post maf vacuum leak which could potentially blow his engine. Replace that inlet ASAP.
That plastic part thats supposed to go on the inlet is part of the mold. Sadly it can't simply be replaced... glued on maybe... but is that really a smart route?
Seems like an easy enough fix. Get a new inlet, and don't drive until then
Yep that's the boost control vacuum line. The vacuum helps to draw out the pressure in the bleed off boost control system. Without this line connected you'll have a hard time making boost with your current WGDC and TD settings.
Beamed at your face at approx. 186,000 miles per second via DROID BIONIC
Facebook me here
Originally Posted by Mikie13
You guys are awesome. Thanks again for your time and have a happy new year!
Facebook me here
I'd still worry like a mofo. LTFT should help under low load but when my after maf had a minor crack(tried sealing it up) it would max out my STFT and caused plenty of knock under boost =(
Posted from a fone.
Facebook me here
Thank you for correcting me, Zax. because I just broke my bittle-ass vacuum lines! The whole damn thing is solid.
Posted from a fone.
