Results 1 to 5 of 5
This is a discussion on 07 wrx cruise is blinking and check engine light is on.. help please within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; So my check engine light turned on a few weeks ago and the cruise control light did too.... I got ...
    Nov 2012
    I got it scanned and what showed up was:
    P0031
    HO2S Heater Control
    Circuit Low (Bank 1, Sensor 1)
    I was told that it was the Oxigen Sensor so i replaced it today...
    The flashing cruise and check engine lights went off so i thought i had fixed it
    but a few minutes later they came back on...
    I tried to reset the ECU by unplugging the battery and pumping the brakes for 30 seconds and again it went away
    for a little but then again it came back on.
    Any ideas?
    Nov 2012
    Montana
    most of the time if you have a flashing check engine light, it means you are doing damage to your vehicle so if it's flashing, I would advise you not to drive it at all if you have been. make sure cruise control is turned off.
    Apr 2011
    Watertown, New York
    Quote Originally Posted by rcorbett3 View Post
    Def dont drive it. Although when i had mine do that it was an a injector prob.
    Feb 2006
    indiana
    Have it scanned again
    zax
    zax is offline
    Tony Vargis zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Flashing CEL typically means large variance misfire. Usually this means the cylinder isn't firing at all.
    Beamed at your face at approx. 186,000 miles per second via DROID BIONIC
    Facebook me here
