thermosat
Results 1 to 7 of 7
This is a discussion on thermosat within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; Hi my car keeps over heating had replaced variously thermostats. But it still over heats. any ideas of whats wrong ...
    Nov 2011
    Suisun City
    thermosat
    Hi my car keeps over heating had replaced variously thermostats. But it still over heats. any ideas of whats wrong with it? started about an yr and half ago still cant figure out whats wrong with the cooling system.
    Registered User Karlosnived's Avatar
    Sep 2011
    OSU
    check the radiator fluid level, at the radiator, overflow, and intercooler resevior. and also check all the lines, it's probably a very slow leak so if one of the lines is bad it'll be hard to see. if there is rubber hosing under some of the lines, check it to make sure it still looks ok and not somewhat shiny or corroded in any way, if it does, it'll be the hose above it most likely. also check the gaskets on the caps make sure they're not shredded.
    I had the same problem where my '04 wrx would overheat randomly, turned out it had a small leak over in the fluid hose over the turbo intake.
    2004 wrx 5-door, freshie in college, miss my car
    Apr 2007
    8000' up in Colorado
    Can you describe the behavior? Does it overheat if you just leave it idling, or do you have to be driving? City or highway driving? How many miles on the car, and has it ever had a coolant flush? How old is the water pump? Does it matter how cold or hot the weather is?
    Scott
    Nov 2009
    Have you burped the system?
    Apr 2012
    im having the same on my 01 i changed the radiator as it was leaking and the thermostat it seems to get warm and fill the expantion tank and not return to the header tank and the bottom hose stays cold can any one help as im ripping my hair out with it ?
    Quote Originally Posted by whiskey View Post
    See your other thread. Burp the system.
    Palmyra, NJ
    Burp
