Results 1 to 3 of 3
This is a discussion on How do I remove and clean (or replace) camshaft sensor within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; Keep getting this code: P0345 Camshaft Position Sensor “A” Circuit (Bank 2) How do I take care of this? Can ...
    Registered User Reverand Hustle's Avatar
    Jul 2009
    NC
    How do I take care of this? Can someone give me directions on how to find and remove the camshaft sensor(s) and how to clean them? Or, is this a situation where I have to replace the one or both? Pictures would be great.
    I have a 2008 WRX STi.
    The camshaft position sensor on the 2L 2002 motor is on the upper outer front edge of the cylinder head to your right as you face the car's nose. In the US this is the driver's side. Tightening torque is 6.4 Nm or 4.7 ft*lbs.
    Jul 2009
    NC
    Thanks for the help. Would you happen to have a picture of that?
