Results 1 to 4 of 4
This is a discussion on Windshield washer pump. within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; Hello, My new to me '08 WRX appears to have a busted windshield washer pump. The wipers and everything else ...
    Aug 2011
    Hello,
    The wipers and everything else works. I didnt see a fuse for the washers it must be on the same fuse as the wipers.
    Any of you ever replaced a washer pump?
    Do I really have to remove the bumper cover to get to it?
    Had the darn car inspected at a shop, they didnt catch the washers not working
    Brian
    First time WRX owner
    '08 WRX sedan
    North Bend WA.
    Registered User scoobaru03's Avatar
    Dec 2009
    Davidsonville, Maryland
    The procedure for removing the motor/pump assy. the step after taking the (-) battery cable off is to remove the bumper cover. It looks like its mounted in a doomass spot. May be able to get to it underneath of the car. Dont quote me on that ive never worked on an 08 just my 03 but the procedure for doing the pump does require to remove the bumper cover. Found this TSB if it is any help.
    FRONT WASHER NOZZLE DOES NOT SPRAY PROPERLY
    Failure of the front washer nozzle to spray properly may be caused by something blocking the nozzle outlet. Try to eliminate dust and foreign matter from front washer nozzle using the following procedure. If the washer nozzle spraying does not change after the repair, then it will be necessary to replace with a new nozzle or inspect other parts on the washer system.
    1) Open the front hood (is there another one somewhere )
    2) Remove the washer nozzle
    3) Blow compressed air in the spray hole of the washer nozzle and the installation hole for washer hose to eliminate dust and foreign matter.
    4) Install the hose to washer nozzle and install the washer nozzle.
    5) Check if front washer sprays properly. If no change, replace with a new nozzle.
    Your nozzle might be fine dont go replacing the nozzle just becuase this says to. This is just giving you a place to start looking just incase your motor might be OK.
    2003 Impreza WRX Sport Wagon
    "I wouldn't want to belong to a club that would have me as a member." - Groucho Marx
    Is it fast? I don't even know if its street legal. O.o (IROC-Z)
    Registered User jgardiner's Avatar
    Oct 2010
    Calgary, Canada
    Can you hear the pump running? Just nothing coming out?
    Aug 2011
    No noise at all from the pump. Seems completely dead. I have seen a couple of posts about people rapping on the washer motor with a blunt object to get it running again.
    Brian
    '08 WRX sedan
    North Bend WA.
