CEL won't turn off
Results 1 to 8 of 8
This is a discussion on CEL won't turn off within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; Got code 0131, so I replace front O2 sensor, disconnected the battery to reset the computer, and the light came ...
    Dec 2010
    CEL won't turn off
    Got code 0131, so I replace front O2 sensor, disconnected the battery to reset the computer, and the light came back on. Had it checked and same code, reset the computer again, this time with the code reader and the light came on again. Some people have been telling me to drive from 50-100 miles and it will go off. Do I still need to drive it to get the light to go off even if I reset the computer? I have a 2003 Impreza WRX.
    The code could be legitimate. Check the wiring again, and search for other reasons you might be getting the code.
    Registered User KnightFury's Avatar
    Sep 2010
    salem, oregon
    there is a sticky floatin around here w/ code reasons
    Sep 2010
    salem, oregon
    Sep 2010
    salem, oregon
    P0131 Front O2 Sensor Low Voltage
    P0131 Front oxygen (A/F) sensor circuit range/performance problem (low input)
    thats what ive found hope it helps, ya should only have to disconnect batt for a few min to allow reset then after driving it may come back on if issue isnt resolved
    Jul 2010
    Cincinnati
    Quote Originally Posted by tjbartle View Post
    No, if the light is coming back, you haven't solved the problem. Could be a circuit issue. Where did you get the o2 from? If it's aftermarket, it could be the problem too.
    Dec 2010
    I originally bought a universal O2 senor made by Bosch, but I'm returning it and getting the OE replacement tomorrow so hopefully it'll work.
    Jul 2010
    Cincinnati
    That's a good idea, those universals rarely work properly
