Results 1 to 7 of 7
This is a discussion on speedometer/odometer not woking within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; anyone know or have this problem my speedometer and odometer is not working on my 05 sti it was working ...
    Apr 2009
    anyone know or have this problem my speedometer and odometer is not working on my 05 sti it was working fine yesterday and now its not working at all the display for the odometer is still there its just not changing numbers and the speedometer has light it is just not reading mph
    Registered User PurpleMongoose's Avatar
    Jul 2009
    Pittsburgh, PA
    Broken speedo cable?
    Stink-Eye Mob #666
    2009 WRX Sedan
    The Kind Administrator. Watch out for the others Trainrex's Avatar
    May 2003
    Quote Originally Posted by PurpleMongoose View Post
    Our cars don't have speedometer cables.
    Do you have a check engine light?
    Jul 2009
    Pittsburgh, PA
    Fair enough. However, the point remains. If the device sending the signal, whether mechanical or digital, is no longer sending (or the receiver no longer receiving) then it would explain why only the speed/mileage is not changing.
    Stink-Eye Mob #666
    2009 WRX Sedan
    May 2003
    Bingo. That's why I asked if he has a check engine light. If the speed sensor is malfunctioning, it will trip a code. If the cluster is malfunctioning, it won't.
    Registered User wrx0131's Avatar
    Jul 2007
    Yonkers, NY
    Quote Originally Posted by Trainrex View Post
    ehh it could go either way.
    I had the same problem, and the code would come on like once every 6 months.
    Sometimes the speedo would go crazy, while other times it wouldnt.
    My miles were also being clocked wrong.
    BTW, it was the speed sensor.
    Bugeye Mafia #213
    Kevin
    2002 Midnight Black Pearl WRX (Traded In!)
    2012 Ice Silver Metallic STi Sedan
    May 2003
    Quote Originally Posted by wrx0131 View Post
    Odds are you had a pending code the whole time.
