Results 1 to 15 of 17
This is a discussion on one man brake bleeding diy within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; don't have someone to help bleed brakes, no problem- Motive brake bleeder is all you need specifically this one (Ford ...
    Jul 2001
    Plains of Eastern Montana
    specifically this one (Ford three prong) Motive Products 0107 - Motive Products Power Bleeder Kits
    get one of these while your at it
    Motive Products 1820 - Motive Products Brake Pressure Bleeding Catch Bottle Kits
    this is really easy, the Motive is also very effective- more effective than the typical two man bleed as you can get long bleeds and pesky pockets you might not have got w/ the two man method
    first loosen all four corner lug nuts, jack up the front and put jack stands (I have always used the pinch welds for stands), repeat in the rear- remove the wheels/tires
    pop the hood, connect the bleeder adapter to the master cylinder- pump the bleeder (empty) till you hit 10 psi (clearly marked on the dial)- this is just to insure there are no leaks, if no leaks slowly (slowly) remove pump top till all the pressure is relieved (don't remove it at the master cylinder under pressure)
    now your ready for your fluid- I like ATE as it comes in two colors, has a high operating temp (wet and dry) and is reasonably priced- the tow colors allow you to alternate between the two- this way insuring a full flush.
    one quart should do the trick, but it's always worth having a second on hand- just don't open the second till needed (once opened the fluid absorbs moisture)
    with the bleeder filled w/ fluid, pump it up to 15psi- it doesn't need to be any higher. It's time to move to the brakes- the bleed order for the WRX is Front Right, Rear Left, Front Left and Rear Right- use this order and no other- this is what the FSM calls for- it's a little odd, but the WRX uses a diagonal system
    remove the rubber cap on the bleeder (don't lose it ), then get a 10mm wrench to crack the bleeder w/- put the wrench on nipple and before cracking it the bleed tube- use the wire to hang the bottle so there is no weight on the tube (lest it pull off and brake fluid goes all over the joint!)
    crack the nipple, let the fluid flow- watch for the color change (it'll be gradual- let it get good and blue)- when your satisfied, tighten the bleed screw (snug- don't get carried away or you'll twist it off!) remove the drain tube and bottle, replace the rubber cover and move to the next caliper and repeat- it's that easy
    when you all done w/ all four corners- slowly remove the pressure by unscrewing the pump cover, once relieved you can remove the cap from the master cylinder insure to drain all fluid out of the bleeder
    start the car up and insure everything is working properly (not driving 75mph down the interstate!) after driving for a bit, check the level of the master cylinder- if it's not to the max line add a little fluid, if it's over take a dropper (clean one) and remove enough fluid to be at the max line
    that's it- easy/schmeasy
    found a video that might help too
    YouTube - Do it yourself brake bleeding
    Oct 2005
    Late Devonian
    Nice write up! I did this a couple of weeks ago, definately prefer it to the speedbleeders.
    Registered User Tinywagon's Avatar
    Mar 2009
    Santa Fe, New Mexico, United States
    thanks big sky, this'll come in handy for my big ol' brake swap this weekend.
    "if you are going to tell someone the truth you had better make them laugh otherwise they'll kill you" - George Bernard Shaw.
    Bugeye Mafia #214
    Dirty Crew #42
    Registered User motherboyxx's Avatar
    Oct 2009
    Philly
    Thanks doing that tomorrow, just found out i need to change my fluid every so often (i am one of those dot 3ers who leaves it in for a decade).
    DUB
    DUB is offline
    Registered User DUB's Avatar
    Jul 2007
    SLT, CA
    Nice work Big Sky. Thanks.
    Jul 2001
    once you use this system you probably won't use anything else- makes bleeding easy and is more efficient than the old two man system
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    I'm getting my whole brake setup changed out here in the next month.. so I'll probably pick one of them up.
    (sorry... PM is coming )
    Nov 2007
    I know this is the WRX forum... but anyone know if the order is the same for the 2.5i?
    Jul 2001
    Quote Originally Posted by Shiggity View Post
    same- they use the same diagonal brake system
    Jul 2012
    Rebirth! I'm finishing a big rebuild/line replacement, and wish I'd have found this before I bought the HF pump. Only got half way before it started to rain. Was thinking it would be nice to be able to connect a liter bottle of fluid to the reservoir to start. Doooh.
    May 2010
    Pittsburgh, PA
    Do you have any suggestions on modifying the adapter? The adapter on mine is a pain to get on, and I chew up my master cylinder a little bit each time.
    +1 on changing brake fluid colors each flush. That's huge.
    2011 STi Build Log
    Jul 2001
    check w/ Motive, they may possible have a better adapter at this point- I can see photobucket did a wonderful job preserving all their photos when they moved to their new version- what a bunch of a$$ hats!
    Registered User Rodman's Avatar
    May 2012
    CT
    Thanks for the info.
    Rod
    2012 DMG WRX base Sedan Cobb S1 93 Octane
    Older than dirt Mob#1
    "Just remember, with great power comes great responsibility" - rarrior
    May 2010
    Pittsburgh, PA
    I doubt it honestly. I will check though - it'd be worth the cash. Otherwise, I have thought about just getting a spare 3 pronger and cutting it back a bit to have it resemble the stock master cylinder lid more.
    2011 STi Build Log
