DIY Engine Compression Test!!! - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
This is a discussion on DIY Engine Compression Test!!! within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; Anyone know of a writeup on how to do a leak-down test for subarus? Thanks!...
    Jul 2012
    Thanks!
    Registered User Jackstand Johnny's Avatar
    Dec 2014
    Virginia
    Im having the same problem. The compression tester I rented from Autozone looks to be way too short. It has a screw on adapter for my spark plug thread pitch which means if I screw it on tight enough into the cylinder, then when I go to unscrew the entire thing it will surely leave the adapter stuck inside the cylinder. I dont have the money to buy an adapter just for a compression tester that I rented. Any ideas here? Loctite the adapter onto the compression tester and hope it holds onto the tester and not onto my cylinder head?
    I hear and I forget. I see and I remember. I do and I understand.
    Dec 2014
    Virginia
  6. #19
    Dec 2014
    Virginia
    As you can see from the last pic, the head of the adapter is MUCH larger than the head of the spark plug. Will a socket even fit around it inside of the spark plug well?
