help... - Page 2
Results 16 to 30 of 45
This is a discussion on help... within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; i am puttin in an oil presure guage... and i was wondering if there was a tapping for it, because ...
    Jul 2008
    New York
    oil presure
    i am puttin in an oil presure guage... and i was wondering if there was a tapping for it, because i was told there was. i have an 05 sti
    DUB
    DUB is offline
    Registered User DUB's Avatar
    Jul 2007
    SLT, CA
    1. Yes, there is a pre-drilled/tapped spot for an oil pressure sender.
    2. This information, complete with installation instructions, is readily available. Search here/nasioc/scoobymods and you should be able to find it easily.
    3. Why is this in the Electronic Engine Management forum?
    Jul 2008
    New York
    boost guage
    i just installed a boost guage on my car and it won't go into a vacumn, and when i m under 10 psi the needlw fulters once i am over 10 psi i it will start to regester. whats the matter? snf i am looking for the tapping for an oil pressure guage on an 05 sti where is it?
  6. #19
    Jul 2008
    New York
    help...
    my check engine light just went on and the cruise control light is flashing... what is wrong, i just had my clutch replaced.....
  7. #20
    Take it back and have them scan the code for the CEL, then have them reconnect whatever they left off if need be (guessing).
    - Al Stewart
  8. #21
    Jul 2008
    New York
    help
    i had my clitch replaced today, then i pit about 15 miles on it and the cruise control light started to blink and the check engine light went on.... does any1 know whats wrong?
  9. #22
    Registered User jeffmm06's Avatar
    Sep 2007
    Sacramento, CA
    Nope, even the admin cant mind read and know what code you flashed, get it pulled and then give us something to work off...
    2005 WRB WRX "was" STAGE 2
  10. #23
    Registered User WRXwagonMAFIA's Avatar
    Aug 2008
    some old backroad
    electronic throttle body or cable? cause with cablt the cruic control is controlled at the throttle body. on the newer ones with electronic, it is patially controlled at throtttle body, and then i know they ahve some kind of selonoid in the transmission that deals with cruise control as well. but still need more to work off of. scan with obdII and let us know what you find
    04' WRB wagon stage 2
    wagon Mafia #1 Where my wagons at?
  11. #24
    Jul 2008
    New York
    it was read and no code came up.
  12. #25
    Is the CEL still on? Does the cruise control still blink?
    - Al Stewart
  13. #26
    Registered User Daddy_WRX's Avatar
    Jul 2007
    Colorado
    I just got the same thing going on in my car today and will be pulling the code tomorrow or tuesday being that I work for a dealership and have a obdII scanner (the perks of working at a dealership)...did your car feel as if it backfired without the noise? that's what mine did. and i have an 07 so it's electronic throttle.
    ~Life is short...DRIVE FASTER!!~
  14. #27
    Registered User Very-Rexy's Avatar
    May 2006
    Warner Robins AFB 30,000 feet
    Quote Originally Posted by ajalfano View Post
    Try to get the code pulled, or go a little more in depth at what you were doing when the CEL popped. Also, in case you didn't know, whenever the check engine light comes on your cruise control is automatically disabled. So those two problems probably aren't related.
    06 WRX - Deadbolt Zilla 20g 365AWHP//358AWTQ//TopSpeed
    STi Drivetrain installed by CRE
    Hawk-Eye Alliance #54
    My mod list
  15. #28
    Jul 2008
    New York
    electronic boost control?
    is an electrionic boost control good for my 2005 sti because i heard that it could leak?
  16. #29
    Jul 2008
    New York
    valentine 1 vs. passport 9500i
    which radar detector is better a valentine 1 or a passport 9500i?
  17. #30
    Better at what?
    Pick one; either performs well enough that you can shop by ease-of-use features, cost, and after-sale service alone.
    - Al Stewart
