Results 1 to 13 of 13
This is a discussion on MAF Cleaner? within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; Anyone knw what the best cleaner is for a MAF sensor? I seen in some posts that they can be ...
    Registered User bandit33's Avatar
    SASK.Canada
    MAF Cleaner?
    Anyone knw what the best cleaner is for a MAF sensor? I seen in some posts that they can be cleaned but am unsure with what, any help would be appreciated, thanks.
    Apr 2007
    8000' up in Colorado
    Go to Radio Shack and get some electronics spray cleaner. Same exact stuff.
    Scott
    Registered User JMack's Avatar
    Feb 2008
    use rubbing alcohol in a spray bottle...
    Why would you need to pay $ X for rubbing alcohol in a compressed aerosol can? 95% of the electronics cleaners on the market is alcohol in an aerosol can...
    Success is the ability to go from one failure to another with no loss of enthusiasm.
    - Winston Churchill
    Ah, the patter of little feet around the house. There's nothing like having a midget for a butler.
    I am free of all prejudices. I hate everyone equally.
    - W.C. Fields
    SASK.Canada
    Wink reply
    Thanks for the replies, i'll try the alcohol, I'll use isopropyl its 99% alcohol that should do the trick, right? I'll let the MAF air dry before re-install.
    Registered User aarond's Avatar
    Apr 2008
    Olympia, WA
    I think I read somewhere on here you can use brake parts cleaner. Is that true?
    I refuse to use brake cleaner.
    DUB
    DUB is offline
    Registered User DUB's Avatar
    Jul 2007
    SLT, CA
    Quote Originally Posted by aarond View Post
    Are you cleaning brakes? No. You are cleaning a MAF sensor. Use MAF sensor cleaner.
    Feb 2008
    to the brake cleaner.
    Isopropyl alcohol will do just fine. Or at least it should.
    I have been in the Electronics maintenance field (aviation) for 7 years, and that is the best thing that I have ever used. I have used the specialty cleaners marketed by various companies, and they just seem to lack the practicality and versatility of alcohol.
    G/L and everything should turn out okay. There really is no need to let it air dry, the evap rate on alcohol is so quick, that it really would not matter at all...
    - Winston Churchill
    - W.C. Fields
    SASK.Canada
    Smile thanks
    Thanks again for all the replies and info. I appreciate it. i needed this info because i am going to install a cold air intake shortly, my car currently has no error codes we'll see after the install.'I'll post the results, thanks again to all who replied and had some input.
    Registered User jimenezp's Avatar
    Apr 2008
    Quote Originally Posted by DUB View Post
    Brake cleaner will work have cleaned many MAFs at work and it works fine.
    Dec 2008
    Eugene, Oregon
    You can use brake cleaner, electronics cleaner, Maf cleaner, and alcohol. What you can't use is carburetor cleaner as it will leave a film on the Maf wires and be just as bad or worse than it was before you cleaned it.
    Jul 2001
    Plains of Eastern Montana
