Results 1 to 11 of 11
This is a discussion on Need a DUI instructions to replace my Front Right drive assembly within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; well, I suspect that my right u-joint is failing because about three months ago when I was replacing my uppipe ...
    Registered User patsquach's Avatar
    Sep 2007
    Watsonville Ca,
    well, I suspect that my right u-joint is failing because about three months ago when I was replacing my uppipe I noticed there was a oil spray pattern on the stock uppipe that lined up with the can shaped object on the axel. I figured the boot had failed and being that, I had only a few miles left before replacing it was needed. so I would like to go about this the right way and with some help with some buddies, I'll be able to save some $$. I have a 03' WRX wagon
    Thanks Again,
    Pat
    Registered User Thug Nasty's Avatar
    Jul 2006
    Denver CO / Portland OR
    Perhaps a DIY? unless you want to Drive Under the Influence while you Do It Yourself.
    -John
    Different Strokes
    Dirty Crew #2002
    Mods in profile.
    Registered User natedawg9640's Avatar
    Apr 2006
    Fox cities, WI
    lol... HA! yeah i noticed that right away too...
    yup
    Registered User ajd111's Avatar
    Jun 2007
    Pittsburgh, PA
    Quote Originally Posted by natedawg9640 View Post
    I'm glad I'm not the only one who though they were seeing things.
    Quote Originally Posted by BrianH View Post
    Careful, I still think she's packin wang.
    Registered User kiger0183's Avatar
    Oct 2005
    SLC, Ut
    haha i guess you could technically "doing under the influence"
    Stage II and loving it!
    Registered User SR55_STi's Avatar
    Oct 2007
    Quote Originally Posted by Thug Nasty View Post
    Check out my DUI thread. It should get you started on the right track. If you want a DUI for sure, drink a bottle of 151, let it settle in your stomache, fight off friends who try to keep you from driving, get in your car, and boost through all the redlights you come upon. LOL.
    Would Never, Ever Say Something Bad About an Admin's Mom SonicWagon's Avatar
    Jul 2007
    Santa Cruz New Mexico
    Step1; Drink many cocktails.
    Step2; Drive around with your doors open in reverse until you are pulled over
    if your front right assembly is damaged as a result of the pitt maneuver take it to a body shop.
    "It is at our most challenging times that we must cheat our very hardest" - Eric Theodore Cartman
    Quote Originally Posted by Weasel 555 View Post
    so whose up for been banned?
    I is teh b1ggest douche evarrrr!~
    Jun 2007
    Pittsburgh, PA
    Quote Originally Posted by SonicWagon View Post
    Jul 2007
    Quote Originally Posted by ajd111 View Post
    damn you got a good ray quote in your signature.
    Sep 2007
    Watsonville Ca,
    Heh I guess i was already UI when i wrote the thread..... Oops
    You guys must have had some fun with that one!
    Sep 2007
    Watsonville Ca,
    Need a DIY instructions to replace my Front Right drive assembly
    I have looked through the DIY forums under the General Maintenance and I couldn't find anything on the subject. I really appreciate the input.
    Wow.... That Sucks. You should get a Subaru!
