what year is it?
This is a discussion on Changing tranni oil? within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; How do i change tranni oil. I am a newbie and, I DONT LIKE TO SPEND MONEY ON SOMETHING I ...
How do i change tranni oil. I am a newbie and, I DONT LIKE TO SPEND MONEY ON SOMETHING I COULD DO. Pls helphttp://www.clubwrx.net/forums/images/smilies/screwy.gif
what year is it?
2005 WRB WRX "was" STAGE 2
look under the tranny there is a nut loosen it and wala tranny fluid not tranny oil comes out
since u dont know its tranny fluid, not tranni oil take it to some one who knows what they are doing
All We'll Drive
DIFFERENT STROKES
POST WH0RE KING
here look at these steps... DIY: Transmission Fluid Change Good luck
Turbo XS BOV, ERZ Down Pipe, ERZ catback, Cobb intake, Perrin Turbo inlet, Perrin Up Pipe, Walboro 255 fuel pump, Ultimate Racing 680cc injectors, gm boost solinoid, Exedy clutch, thermo tech turbo heat wrap, perrin light weight pulley,TGV delete's, 8mm intake manifold phenoic spacers, TXS racing FMIC, Tial 38mm wastegate
Tuned By DPS
http://www.dpstuning.com
Team Downshift Member
Don't remove the IC, use a long narrow funnel instead. Be sure to use jack stands to properly support the car.
Be careful what you put in there... my first gear syncro doesn't like the valvoline 75w90 i put in. You might want to try the scott's cocktail... but then again I have an '02 and my tranny sucks a lot more...
