Results 1 to 6 of 6
This is a discussion on engine mounts and wheel noise!! within the Maintenance, service, and repair forums, part of the Tutorials & DIY category; When if at all should you replace your engine mounts. Ever since i got in my accident i been hearing ...
    Apr 2007
    When if at all should you replace your engine mounts. Ever since i got in my accident i been hearing noises not heard before. example my right rear wheel makes a noise like if the rotor was warped and kept tapping on the brake pad so i relpaced the rotor and pads and it still is there so i think maybe the wheel bearing is shot but when i lift the car no wiggle in the wheel. any suggestions? also after like 20 mins of driving my exhaust starts to rattle. enough that it broke the hanger that was welded to the downpipe and i had to get it rewelded. i think it the motor mounts since every thing else is tight. i think its hitting the bracket that connects the center diff to the body. anyway if i go over a bump or make left turns is when i hear it also when i let off the gas at a high RPM. its starting to drive me nuts cuz i cant figure out what it is. all the suspension underneath the car is tight. i dont have a lift so i cant really check it out as good as i want to but i did what i could. any suggestions or experience with this problem? also the dog bone behind the motor is still solid it didnt break, i thought about that first.
    Apr 2007
    bump this up
    Registered User WRXcruiser's Avatar
    May 2005
    Seattle, Washington
    when you start your car does the engine wiggle while its idling enough to feel when your sitting in the car?
    2005 WRX Wagon stg 1 - 3/12 to present
    1996 BMW 328is coupe - 5/11 to present
    02 WRX wagon stg 2 - history
    WTB: Cobb Accessport ap-sub-001 for 2005 WRX
    Apr 2007
    i has always wiggled since i put the exhaust and intake on and stage 2ed it.. well i havent looked at the engine but it rocked a bit while sitting in the car.
    Registered User Death To Ricers's Avatar
    Jan 2004
    Phoenix, AZ
    Bump because I am having a similar problem. Tonight I was driving and I heard a thump, as if I had ran over something, but nothing was there. Now I am hearing almost like a rubbing sound from the rear right wheel. It was dark so I checked as much as I could and nothing was rubbing to my knowledge. I checked the suspension, springs, body, bumper, the works. I am honestly stumped. I am going to take it to my tire guy tomorrow who has a lift and check it out. I hope it is something small. I have a 650 mile drive on monday.
    2006 WRX
    You could vote to fix me a sammich.
    Jan 2004
    Phoenix, AZ
    Well, took it in, had it up on the lift and everything seemed fine. Wheel bearings are fine and everything. On my way to the shop I could not hear the sound I was hearing last night. I guess that is a good thing. Hope this does not come back to bite me. I have 1,000 miles until the warranty is up, so I hope if it does come back, it does it in the next thousand miles.
    2006 WRX
