Results 1 to 8 of 8
This is a discussion on Oxygen Sensor for Import within the International Forum forums, part of the Regional Discussion category; Hi Guys, I know there are a ton of posts about oxygen sensors, but i havent been able to find ...
    Registered User PHTBMA's Avatar
    Dec 2009
    New Zealand
    Hi Guys,
    I know there are a ton of posts about oxygen sensors, but i havent been able to find what I need.
    I have a 99 WRX JDM version and it is really hard to find the right o2 sensor here in aus. I have managed to find the right part number etc by calling the dealership in New Zealand.
    I want to buy one online as it seems like i can get a Denso sensor from the states for a really good price but I dont know if they will fit my car as the listing only show 2.2l engines in the 99 model. The part number for mine is 22690-AA391.
    Any help would be greatly appreciated.
    1999 WRX Wagon
    STI bits
    Resident meany-rator 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Well if you know what the Denso # is supposed to be for your car, then disregard what the stateside application lists. We never got the JDM motor here, only the 2.2 in the legacy. I know several companies used to import the JDM wrx 2.0L engines and parts were available here.
    How many wires is the o2 sensor, 4?
    Dec 2009
    New Zealand
    That part number is actually the oem part number so not sure wat the denso part number is.
    1999 WRX Wagon
    STI bits
    Jun 2006
    Nor Cal
    Trim/Engine Part # Notes Qty Pos Label
    Air Fuel Ratio Sensors
    2.5I, OUTBACK SPORT Engine: H4 (2.5L)
    234-9123
    (Air Fuel Ratio Sensor)
    Non-Turbo; DENSO is the O.E. Manufacturer / Air Fuel Ratio Sensor 1 Upstream OE Style
    WRX Engine: H4 (2.5L)
    234-9120
    WRX LIMITED, WRX TR Engine: H4 (2.5L)
    234-9120
    WRX STI Engine: H4 (2.5L)
    234-9120
    Oxygen Sensors
    234-4445
    (Oxygen Sensor)
    Non-Turbo; DENSO is the O.E. Manufacturer 1 Downstream OE Style
    234-4732
    (Oxygen Sensor)
    234-4732
    (Oxygen Sensor)
    234-4732
    (Oxygen Sensor)
    WRX Engine: H4 (2.0L)
    234-9011
    Oxygen Sensors
    234-4732
    (Oxygen Sensor)
    Jun 2006
    Nor Cal
    Standard, OUTBACK Engine: H4 (2.2L)
    VIN: 4
    234-9018
    Calif.; Calif.; DENSO is the O.E. Manufacturer / Air Fuel Ratio Sensor 1 Upstream OE Style
    234-9018
    Oxygen Sensors
    234-4706
    (Oxygen Sensor)
    Canada Model; Canada Model; O.E. Quality Replacement Sensor 1 Downstream OE Style
    VIN: 4
    234-4706
    (Oxygen Sensor)
    234-4706
    (Oxygen Sensor)
    Exc. Calif.; Exc. Calif.; O.E. Quality Replacement Sensor 1 Downstream OE Style
    VIN: 4
    234-4706
    (Oxygen Sensor)
    234-4736
    (Oxygen Sensor)
    Calif.; Calif.; DENSO is the O.E. Manufacturer 1 Downstream OE Style
    VIN: 4
    234-4736
    (Oxygen Sensor)
    VIN: 4
    234-4700
    (Oxygen Sensor)
    Canada Model; Canada Model; O.E. Quality Replacement Sensor 1 Downstream Universal
    234-4700
    (Oxygen Sensor)
    VIN: 4
    234-4700
    (Oxygen Sensor)
    Exc. Calif.; Exc. Calif.; O.E. Quality Replacement Sensor 1 Downstream Universal
    234-4700
    (Oxygen Sensor)
    VIN: 4
    234-3091
    (Oxygen Sensor)
    Canada Model; Canada Model; O.E. Quality Replacement Sensor 1 Upstream OE Style
    234-3091
    (Oxygen Sensor)
    VIN: 4
    234-3091
    (Oxygen Sensor)
    Exc. Calif.; Exc. Calif.; O.E. Quality Replacement Sensor 1 Upstream OE Style
    234-3091
    (Oxygen Sensor)
    VIN: 4
    234-3090
    (Oxygen Sensor)
    Canada Model; Canada Model; O.E. Quality Replacement Sensor 1 Upstream Universal
    234-3090
    (Oxygen Sensor)
    VIN: 4
    234-3090
    (Oxygen Sensor)
    Exc. Calif.; Exc. Calif.; O.E. Quality Replacement Sensor 1 Upstream Universal
    234-3090
    (Oxygen Sensor)
    Jun 2006
    Nor Cal
    RS Engine: H4 (2.5L)
    234-4706
    (Oxygen Sensor)
    234-4700
    (Oxygen Sensor)
    234-3091
    (Oxygen Sensor)
    234-3090
    (Oxygen Sensor)
    Jun 2006
    Nor Cal
    Those are all the US models and their sensors. Denso was the OE mfg for the EJ205 which we got in 2003, but our cars came OBD2 while the 1999+ JDM models were just OBD, so idk if that made a difference. Usually here any car that came obd 2 has either a 2,3, or 4 wire O2 sensor. OBD 1 cars came with a 1 wire sensor.
    You guys don't have a national auto parts chain that will have aftermarket equivalent parts?
    Oct 2011
    Santa Ana, CA
    ^^Officially banned from the Vietnamese ethic group.
