Boost Gauge Options Q - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
This is a discussion on Boost Gauge Options Q within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; My VDO setup... 1...
    Registered User is2scooby's Avatar
    Jun 2002
    Honolulu, HI
    My VDO setup... 1
    Aloha, Richard...
    Retired Moderator
    TXS Stage 4 UTEC + TMIC + JoeP
    12.75 @ 105.67mph - 1.74 60'
    Jun 2002
    Honolulu, HI
    Vdo 2
    Aloha, Richard...
    Retired Moderator
    Jun 2002
    Honolulu, HI
    Vdo 3
    Aloha, Richard...
    Retired Moderator
  6. #19
    Registered User GonzoWRX's Avatar
    Jun 2002
    Savannah GA
    Window defroster
    Hey IS2SCOOBY does that setup block the defroster from the driver side window? Props on the setup.
  7. #20
    Jun 2002
    Honolulu, HI
    Thanks for the props. :-)
    I'm not sure regarding the defroster, I live in Hawaii. Have never even turned on the defroster. I don't suppose that it would completely block the defroster.
    If anything the boost gauge would get hot and read high.
    Aloha, Richard...
    Retired Moderator
  8. #21
    Registered User madmmt's Avatar
    Aug 2002
    Thanks, That looks great. Did you route the wires through the vent???
  9. #22
    Jun 2002
    Honolulu, HI
    The wires are routed through some wiring loom out of the back of the gauge cup into a hole I drilled into the a-pillar.
    Thanks for the compliments! It's simple, low-buck, and clean. The way I like my mods!
    Aloha, Richard...
    Retired Moderator
  10. #23
    Tustin, CA
    How did you mount the support tube that's coming out of the vent? Did that come with the cup? How long did the install take? I already have the VDO gauge, just deciing where to put it. BTW how well does the lighting match at night?
  11. #24
    Jun 2002
    Honolulu, HI
    Hehehe. The "support tube" is a piece of 3/8" Semi-Rigid Vacuum line from an autoparts store cleverly cut to exacting tolerances to dampen excessive cup oscillation.
    It's just propped in there between the cup and the vent. Works great, everybody thinks it's part of the cup and it cost like $0.12
    The lighting matches EXACTLY. I'm *VERY* happy with my low-buck gauge.
    The VDO cup is a bit of an unfriendly sort so it took me about 2 hours total to get everything going...
    Aloha, Richard...
    Retired Moderator
  12. #25
    Registered User palaban's Avatar
    Mar 2002
    Hawaii
    Thumbs up
    Looks great Richard!!
  13. #26
    Registered User WRXin''s Avatar
    Jun 2002
    Houston, TX
    Originally posted by SpeedRacerWRX02
    boost gauge
    Interesting setup dude...much props on the creativity of the placement
    Fahd
    Floats like a butterfly and stings like when I pee!
  14. #27
    Registered User PKer's Avatar
    at work
    If you don't already have a turbo timer you might want to get the Blitz Dual TT and mount it next to the cup holder. This Turbo timer also displays boost with peak hold. I like this because the color matches and you get two functions with one device!
    This TT is relatively cheap (I think less than 200). I love mine.
  15. #28
    Registered User CustomS10's Avatar
    Nov 2002
    Western Mass
    thanks but as i'm sure you've seen the updated pics i picked up an a pillar guage pod and tossed a new autometer gauges in there with a shift light
    -Ben-
    Spark it or Park it!
  16. #29
    Jun 2002
    Honolulu, HI
    Pic of my VDO setup at night...
    Aloha, Richard...
    Retired Moderator
  17. #30
    Registered User RogersWRX's Avatar
    Jan 2003
    Highlands Ranch, CO
    I'd recommend the Omori boost gauge - it's in lbs, and matches the factory gauges with a yellow needle and green backlight.
    It can be installed in the factory rubber column pod housing...
    I got mine from here...
    http://www.j-spectuning.com
