Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
This is a discussion on Pics of aftermarket units within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Originally posted by Jeffsw_02WRX xlrater, what is that little digital readout below your Cig. lighter jack? Is that a turbo ...
    Registered User Jeffsw_02WRX's Avatar
    Sacramento, CA
    xlrater, what is that little digital readout below your Cig. lighter jack? Is that a turbo timer?
    Okay, after a little research, it looks like you have an Apex Turbo Timer. How did you install that? Where does the wiring connect at? Did you do it yourself? I'm interested in getting on of those...
    AIM: jeffsw1981
    email: jeff_s_w@yahoo.com
    2002 WRBlue WRX (Stock)
    Factory installed options:
    Short Throw Shifter
    Premium Sound System
    Turbo Boost Gauge
  2. #17
    Portland, OR
    Hello Jeff,
    Yes you are correct. It is the Apexi turbo timer.
    I installed it myself and it was a very easy install. Well, with the help of a wiring harness.
    If I remember correctly there are 3 main wires coming out of the central unit for the tt(turbo timer)
    1. A group of wires which easily plugs into the wiring harness
    2. Wire that hooks to your E-brake
    3. Wire that hooks into your ECU to show the Air/Fuel mixture.
    I didn't hook up the air/fuel mixture cause I'm not ready to mess with my ECU yet. But just hide the central unit in the dash and drill a hole (covered with a rubber gromet) below the ash tray, connect and your set.
    Try doing a search and you will get alot more details.
    Hope this helps
  3. #18
    Registered User BoarderEight's Avatar
    Jan 2002
    NORCAL NATIVE
    Not a WRX, but a nifty idea for that second DIN slot:
    those CF gages look so cool!
  4. #19
    Mar 2002
    orange county
    pioneer
    here is my setup
    starks
  5. #20
    Portland, OR
    Thumbs up
    Nice setup Starks
    So is the top din a lcd with dvd and the bottom din a six disc changer or something?
    (hard to tell with the pic)
    What else are you running in there? (speakers, amp, etc.)
    Sweet!
  6. #21
    Jan 2002
    NORCAL NATIVE
    Looks beautiful Starks.
    I can see you were watching The Fast And The Furious at the time
  7. #22
    Registered User WRXin''s Avatar
    Jun 2002
    Houston, TX
    Re: pioneer
    Originally posted by starks_25
    here is my setup
    starks
    That's the setup I want...except that I have a Blitz FATT DC mounted next to the cup holder. Will that interfere with the screen folding back?
    Fahd
    Floats like a butterfly and stings like when I pee!
