Has anyone's clock died?
Results 1 to 15 of 30
This is a discussion on Has anyone's clock died? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; It's started acting up about a week ago -I would start the car, and the clock display would be off. ...
    Oct 2002
    MD
    It's started acting up about a week ago -I would start the car, and the clock display would be off. Then after a few minutes, it came on (clock reading was OK). Now, it's completely dead. I worked on it today -fuse is OK, and the clock itself receives power the way it should (12V to clock, 12V to display -only when key is in ignition).
    Has this happened to anyone else?
    -09 Impreza 2.5GT 13.72/ 99.4/1.926
    -99 Mustang 10.64/136.41.57
    -08 R32 (bone stock)
    Jan 2003
    Until you wrote this thread I thought I was the only one. My clock went about a month ago. The fuse was fine too I was thinking a loose wire because of how it went on and off like it did. I haven't gotten the time to check it though. The clock probably went because of all the pot holes we have around here. I haven't brought to Subaru yet because I don't want to get charged $200 for a loose wire or a clock.
    Oct 2002
    MD
    I think it's the LED display, since everything else is OK. It's easy enough to replace, but I wonder how much Subaru will rape me on the new part.
    Oct 2002
    MD
    Update:
    Got a new clock from Subaru for 50-something dollars. Sure enough, that was it. It's very easy to replace -just pop out the dash panel, unplug the old clock, replace with new clock and your done.
    May 2004
    Buchanan, MI
    Have an '03. Clock was bad when I brought the car new. Drove it home anyway while the dealer ordered replacement which was covered under warranty. Clock display always showed 12:00 no matter what you did. Would have considered trashing the clock in favor of center gage pod but the car already had a steering column mounted boost gage installed.
    Aug 2002
    Virginia Beach, VA
    happened in my dad's forester...it's the same clock, different location. I assume it was the evil "japanese car fairys." They're responsible for everything that goes wrong in our subies
    Oct 2004
    Boulder, CO
    mine died too
    Clock petered out after a mtn biking trip to Fruita, CO - apparently it didn't like the dirt roads there.
    Any one come up with a cheap repair?
    2002 Rex - Blue Wagon
    Registered User Sun Burn's Avatar
    Jax, FL
    Just replace your clock with a nice gauge pod and some gauges. That will solve the problem.
    2005 WRX Sedan
    2005 Honda CRF 50
    2003 Suzuki GSXR 600
    1994 Suzuki Sidekick (Beater)
    Oct 2002
    MD
    Quote Originally Posted by ewingmh
    $50-something dollars for a new clock from Subaru. Simple 5 minute repair.
    Oct 2004
    Boulder, CO
    simple repair
    How does one simply "pop" out the dash panel? Maybe while I'm in there I can tighten up all the rattles and squeaks... they're fun fast cars... but they're definitely not well built on the interior.
    Mar 2007
    Coldsville, MN
    TonyG,
    That's exactly like what happened to mine. I thought it was just a cold-weather connection, as it would come back on when the interior warmed up, but soon completely quit ...
    I did some web-searching, and some guy claimed a loose resistor was the problem. So, being the adept repair-man that I think I am, I pulled it apart this afternoon. Yes, I broke two of the small tabs holding the clock into the dash pod, and all three tabs holding the clock circuit board in, but it went back in just fine.
    I pulled the clock body apart, desoldered and swung the LED assembly up out of the way, and sure enough, the 510 ohm resistor's left solder was broken! A little gentle heat and solder, put it all back together, and Cooool, it works again! (for free too!) Just be careful of all the plastics; they don't bend back into place very well.
    I was so proud of myself, I had to let someone know. (my girlfried didn't think it was such a big deal, but I knew better)
    Jan 2007
    Yankee Land
    I have the SPT gauge cluster, so no clock. I used a $10 clock from the auto part store to resolve this issue (w/double sided tape).
    04 wrx wagon D/D
    02 S2K Summer Fun (sold)
    Registered User powder's Avatar
    Aug 2006
    WA State
    if this happens to me i'm just gonna go find one at the bone yard. mines been flashin oddly lately.
    Blobeye Syndicate #2004
    Military Militia #30-06
    2004 WRX - JBP:Stage 2:13.93 @ 96
    Wingless alas. Too bad it took a 50 ton truck to make it happen.
    Oct 2002
    MD
    Quote Originally Posted by buymywit View Post
    TonyG,
    Good info. I probably could have saved money and repaired the bad solder joint if I was as thorough as you.
    Registered User Business810's Avatar
    Aug 2006
    Pittsburgh, PA
    My clock has been dead for about a month now. Last weekend I pulled it out of the dash to check out the resistors, only to find that they were all intact. The LED screen itself appears to be the culprit on mine though, since it has this burned/different color look to part of it (it's hard to describe), so it looks like I'll have to be ordering one from the dealer.
