Help: Green Connector Under Dash
Results 1 to 8 of 8
This is a discussion on Help: Green Connector Under Dash within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Under the driver's side dash, behind the coin holder, there is a green connector (both male and female) that is ...
    Aug 2002
    Weston, Florida
    Question Help: Green Connector Under Dash
    Under the driver's side dash, behind the coin holder, there is a green connector (both male and female) that is just dangling there, unconnected. Does anyone know what it is for before I connect it ? Thanks.
    Raj
    Registered User ryland's Avatar
    Apr 2002
    NY
    I think it resets the ECU, its meant to be disconnected.
    repeat:
    Do Not Connect IT!
    2004 Black WRX Sedan
    Mods = yes
    Aug 2002
    Weston, Florida
    Question
    If it resets the ECU, why does everyone disconnect the battery? This is much easier. I think it is for some other purpose.
    Registered User is2scooby's Avatar
    Jun 2002
    Honolulu, HI
    This appears to be the diagnostic connector the dealership would use to reset your ECU:
    (Found this with a google search eventually on MRT's website)
    ECU clear memory procedure is as follows for auto and manual transmissions:
    With engine at operating temperature, turn engine off. Place gear shift lever into park (auto transmission cars only)
    Locate the two ECU check connectors, for most cars they are located under the steering column and consist of a black plastic male and female connector, and a green male female connector. The exact location of the connectors varies with the different year models, but generally they are located under the steering column on the drivers side.
    NOTE: sometimes they are still taped over with some small amount of plastic tape, so look hard, they will be there!
    With the ignition OFF connect black to black and green to green.
    Turn on ignition, do not start the engine, (and for auto transmission, cycle the gearshift lever from park to neutral and back to park ), depress the accelerator pedal to full throttle and hold for a few seconds, and then release.
    Start engine and then drive for at least one minute, keeping road speed above 11 Km/h.
    ECU is now re-set.
    At this point the check engine light should start to flash the all clear signal (steady 1/2 second interval flashes). If the check engine light does not flash, or indicates some other sequence, there is a fault present in the system, and should be professionally checked for necessary repairs.
    Once, stop the car and turn off the engine.
    Disconnect the plugs
    Aloha, Richard...
    Retired Moderator
    TXS Stage 4 UTEC + TMIC + JoeP
    12.75 @ 105.67mph - 1.74 60'
    Registered User WRXed's Avatar
    Nov 2001
    Macon, GA
    I've often wondered that myself. It seems to me, much easier to do it this way, and requires way less time to do it (IIRC, you disconnect battery for 20-30 minutes to reset that way).
    All those who believe in psychokinesis, raise my hand. - Steven Wright
    Moderator, of the "Super" persuasion
    Registered User djrez4's Avatar
    Colorado
    you don't have to disconnect for any specific amount of time. it's simply a question of getting all of the data out of the ECU memory. diconnect the battery, hit the brake pedal a few times, reconnect the battery. doesn't take more that 5 minutes.
    Deliberating enclaves of like-minded people are often a breeding ground for extreme movements - Cass Sunstein
    Moderator aussieinstlouis's Avatar
    Jun 2002
    S34 47.322 E138 29.131 (WGS84)
    that green one!! I asked the dealer about it and he didn't know (he was the service manager) but when you do connect it, the CEL will flash - so I disconnected it again and let well alone!
    I'm not sure if it does reset the ECU.
    Banned dark_rex's Avatar
    Aug 2001
    The Hub
    when you connect it and drive, i think the car goes into "limp mode" or diagnostic mode. it's so service techs can analyze the ECU storage easitly.
    see HERE
    dR
