i'm not an expert but others out there will correct me.
You can go 1 of 2 routes. Wire the two coils in parallel yielding a 2 ohm load.... or wire them in series which'll give it an 8 ohm load. Many installers here say do not run only 1 vc on a dual vc speaker. Something about not good or not efficient..(guys correct me if i'm wrong)...
If your amp is stable at 2 ohm in one channel(bridged mode).. then go the 2 ohm route for most efficiency. If your amp is not capable of doing this... run it in 8 ohm load to be safer. You can always buy another dvc 4ohm per coil sub and make it 4 ohms. Your amp will run cooler, but the speaker will not sound substantially loud, if you run it in 8 ohm load cause the amp will not deliver the best of its abilities at that load.
LinkBack URL
About LinkBacks
