bump.
Anyone?
This is a discussion on 52 mm gauge pod within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I've searched unsuccessfully looking for a gauge pod to accomodate a single 52mm gauge. Preferably to be located on the ...
I've searched unsuccessfully looking for a gauge pod to accomodate a single 52mm gauge. Preferably to be located on the steering column. Has anyone located such a part? I don't want to use the AC vents.
I also recall someone posting a link for a threaded fitting to weld to the exhaust manifold. Can't find that either.
misterx
I used a greddy 52mm bracket type mount. Its a metal band that fits around the gauge and connects into a lower mount which you can put basically anywhere...
I got mine from worldoneperformance.com under products-gauges-greddy-gauge mounts for like $9
EDIT: You can order the fittingband holder for 52mm, and it comes with everything you need (ie a band). I found that confusing when I made my order.
