Results 1 to 3 of 3
This is a discussion on USDM Sti ver 8 Cluster F up's within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Ok I have installed the cluster in my 02 WRX , and now my radio and clock are not working. ...
    Dec 2004
    Ok I have installed the cluster in my 02 WRX , and now my radio and clock are not working. I have read a post from a while ago and followed the install instructions but I am still having this problem. Could anyone give me some insight.
    Thanks
    ClubWRX.net Vendor
    Mar 2004
    Los Angeles
    You blew a fuse. I didn't have this problem, but have fixed it for customers numerous times. The airbag light will also turn on, when switching from an 02 to an 04 cluster. There's a resistor that will help fix this though. Check your fuse box, it's behind your change compartment on the left bottom of your dash.
    Aug 2003
    yeah I just installed it as per the instructions on the following site
    http://www.rspeed.org/howto/sticluster.php
    I have no issues with the radio. I think you probably didn't cut that b28 wire, that is why you blew the fuse to the radio.
