What size Optima Yellow top fits a 2002 WRX Sedan??
Results 1 to 4 of 4
This is a discussion on What size Optima Yellow top fits a 2002 WRX Sedan?? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I've tried searches, but most people only talk about the red top. However, I need a yellow top that will ...
    Registered User Hybrid-X's Avatar
    Feb 2002
    WA for now, but CA will always be home
    I've tried searches, but most people only talk about the red top. However, I need a yellow top that will fit properly without having to modify the positive terminal cable length, modify the battery tray, etc. What is the model # and or size of yellow top that fits? Thanks in advance.
    Edit: It's a given, but I need a comparable yellow top w/ the reversed terminals found on the 35R red top.
    Registered User fsmwrx's Avatar
    Nov 2003
    Tigard, OR
    It should be the 51R that they made in the yellow top for all the honda/acura applications. It's a lot narrower and slightly taller than the 35/75 red top, but should work.
    03' PSM WRX sedan - 326 awhp/303 tq
    Nov 2004
    unless your using the yellow top for car audio you need a redtop for ignition and such
    Nov 2003
    Tigard, OR
    I pretty sure there is actually a new yellow top that is made specifically for sport compact and is not a deep cycle, but a regular starting battery and that was what I was refering to above.
