OEM Sub on Aftermarket Head Unit
Results 1 to 11 of 11
This is a discussion on OEM Sub on Aftermarket Head Unit within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Is it possible to get the OEM Sub hooked up to an aftermarket deck? I'm looking at replacing the deck ...
    Registered User Racenut's Avatar
    Dec 2002
    California
    Is it possible to get the OEM Sub hooked up to an aftermarket deck? I'm looking at replacing the deck with a satelite ready unit, but don't want to loose the sub. As lame as it is, it's better than nothing, already in the car, and is basically invisible.
    Oct 2003
    It's possible, though I couldn't give you the technical how-to data. Mine is still hooked up to my Alpine unit, though I also have an aftermarket sub.
    ClubWRX.net Vendor
    Mar 2004
    Los Angeles
    Quote Originally Posted by Racenut
    I'm sorry for asking the obvious...but why would you do that??
    Granted, the sub is light, not very loud, but you can buy aftermarket subs and amps that weigh only slightly more, yet sound exponentially better. If trunk space is a problem, there are boxes around that will allow you to retain much of your trunk, and still get very good sound.
    I'm not trying to mock or disrespect you, but you should really consider slapping that OEM stuff on ebay and using the spoils to get some better tunes.
    Dec 2002
    California
    Quote Originally Posted by ej20fan
    Like I said.. it's already there... just trying to keep the cost down. Being married with two kids kinda sucks that way All of a sudden, satelite radio goes from a $100-150 add-on to a $500 can of worms.. tends to make the wife grumpy, so then I have to spend $500 on her... and then the kids are feeling left out.. so $500 is only fair for them... each... all of a sudden I'm out $2000 for satelite radio
    Registered User m r g s r's Avatar
    Sep 2004
    Who says they all need $500 worth of stuff. Take the $2k and put it all into your car! duhh!
    1997 Milano Red GSR GT32E powered, LSVTEC
    mo pOwA than ur subiE bicH! jk...but shess quikk
    1997 milano red Civic
    SI wannabeeeee
    Dec 2002
    California
    Quote Originally Posted by m r g s r
    You're not married are you?
    Registered User Wrinkleboi's Avatar
    Jan 2002
    Langhorne, PA
    just fyi, you can prob sell your oem sub for $100... and you could pick up a new infinity basslink online for about $200. it sounds infinitely better, and thats only the tip of the iceberg. some audiophiles say the basslink isnt good, but for my untrained ears the thing is a great value, gets pretty freakin loud, and doesnt take up much space at all... and at $100 used, who was i to say no? .
    bryan
    -2003 Blue WRX, complete 2007 STi Engine/Drivetrain transplant - Pic 1 | Pic 2 | Pic 3 | Pic 4 (new!)
    -1994 Black Supra TT 6MT - Pic | Build/Restoration Thread: 67mm, Fuel, Painted Engine Bay, Fuse Box Relocation, Wire Tuck, etc.
    www.TriStateTuners.com
    Sep 2004
    Quote Originally Posted by Racenut3.0
    Nope, I better not be, I'm 18!
    SI wannabeeeee
    Dec 2002
    California
    Quote Originally Posted by Wrinkleboi
    The Basslink would take up too much space anyway, I don't ride around with a bowling bag in the trunk for the same reason Clarion makes a sub that is similar to the OEM, but a little bigger. I think it's a 7" driver. And Kenwood makes a low profile sub too, but it wouldn't fit under the seat but I have seen them put on the back seatback.
    Clarion - http://www.crutchfield.com/S-MuHPtAe...SRV303&g=51000
    Kenwood - http://www.crutchfield.com/S-MuHPtAe...00&I=113WA62RC
    Anyone have any opinion on those?
    Feb 2005
    Did you ever get an answer to the original question? I too want to utilize my factory sub with an aftermarket head unit. I like the location and concealment of the sub, and don't want to spend additional money replacing anything. I was emailing Crutchfield and they said it hooks up to their wiring harness's "BU" wire. What does that mean? Is "BU" a standard wire?
    Here is the wiring out:
    12V Igniition / ACC - Red
    12V Battery / Memroy - Yellow
    Ground - Black
    Power Antenna - Blue
    Amp Turn-on - Blue / white
    Amp Ground - Black / white
    Illumination - Orange
    Dimmer+ = Orange / white
    Dimmer- - Orange / black
    Phone Mute - Brown
    The rest are for Right / left fronts & rears.
    Registered User 04wrx4keeps's Avatar
    Apr 2003
    Central NY/ Western PA (for school)
    I havent actually seen or worked with the factory sub fist hand, so this is just an educated guess here, but i have delt with amp sub setups on other cars. There may be a wire at the harness on the amp that turns the factory amp in the sub unit on when the radio comes on. This probably wouldnt be too hard to find with a volt tester, then just run that to an accessory line so it comes on when the car comes on. If its wired anything like the front door speaker setup may just should draw its signal off the other 4 chanel outputs on the radio.If not though... If you get a harness for the factory connection (rather than just trying to cut and splice all the wires yourself) there will more than likely be open plugs on it that have wires on the car side that are the sub outputs, test them, and tap those to the rear speaker wires and that should account for the signal to the sub. As long as the aftermarket deck and the sub's amps work together you should be fine.
